Old 10-23-2019, 02:41 PM   #1
coachmen pursuit tv problem
How do I remove a wall mount tv from the rv (living room and outside tvs) I want to attach a HDMI cable to both of them. I have tried everything and cannot get them out. I don't see any straps or latches, etc, holding them in.
T> Thanks,
Becky
Becky Morris is offline   Reply With Quote
Old 10-23-2019, 03:07 PM   #2
WDW
If they are like (and probably are) leveraged prying is the key. Itís probably a slotted fit bracket.
WDW is offline   Reply With Quote
Old 10-24-2019, 07:05 PM   #3
It lifts up and then out at least for the living room TV. I have removed it to attach a HDMI cable and plug it into a inverter. I think the outside one is more permanently mounted.
2016 Pursuit 29sb
JimRynd is offline   Reply With Quote
Old 10-24-2019, 08:43 PM   #4
I have tried doing that among other things. Nothing works!
Old 10-25-2019, 06:11 PM   #5
Pursuit TV mounts
Attached is photos of the mount and back of TV when removed from kitchen area. It took a lot of effort the first time to remove it.
ID:	218042   Click image for larger version
Name:	TV mount.jpg
Old 10-25-2019, 08:54 PM   #6
Same as above. Check the screws for tightness I had one screw fall out and found the other three were loose on our return of this last trip.
Okie Dokie 2 is offline   Reply With Quote
Old 10-28-2019, 08:23 PM   #7
After much coaxing, I was finally able to get the living room TV out. Mine was just like the picture you posted. Thanks for your help. I'm still working on the outside TV. More complicated!
