Old 04-27-2024, 06:52 AM   #1
Dose size matter between Li3 and Pure shine?
Yes, I own and enjoy our Greta 2021 Galleria with Li3, which currently has 630Ah. With 8 to 10 hours of stand-alone time before recharging is required.
* A. My Li3 Lithium Battery – 630 amp-hour lithium battery.
Voltage regulator, Xantrex XC Pro 3,000W inverter/ charger.
* B. The E1, a Pure sine at 6.900 Watts alternator. a high-
capacity 12,000-watt-hour lithium battery pack, a 3,200-watt
pure sine inverter, two 30-amp converters, and a secondary 51-
volt alternator, also with 8 to 10 hours of stand-alone time
Which is a better power system and how can I tell, s writing my little brain around the numbers? My issues are few, and both are Mercedes-Benz. That is no problem, I like MB. The B Van has a 144WB and our Greta which is "A" package has a 170WB. I do wish Coachmen made a 144WB in the Mercedes-Benz package as I do like our Galleria campervan, but they don't. I have reviewed tapes and information on the E1 systems and can't make heads or tails from the numbers. Which for me comes down to want and need and letting go of a larger VAN. As we near our 80s, we seem to be hitting hotels much more than we once did and it helps with a full night to recharge our human batteries.
Sadly, this is all the information and data I have at this point on both systems. Truly, no idea what I should be looking for in electrical power output systems? as stand-alone running times. A or B, your thoughts?
DogMan635 is offline   Reply With Quote
144wb, 170wb, inverters, li3, motorhome, pure sine, size, vota
