Old 01-09-2014, 05:43 PM   #1
Fan running desperate for some quick help please
We have my daughter's 2011 Coachmen Freelander 27qb for 6-7 months testng to see if we want to purchase our own RV. We are new at taking care of a RV and the info we were given didn't help much (here's the books).
Over Christmas we plugged in the RV and let family sleep in it. The heater was turned on and we discovered yesterday that the heater had never been turned off. We unplugged it from the house current approx the 30th.
Never heard any noise from the RV until yesterday when the heater was turned off. Problem now is that a fan is running and blowing air and we don't know how to make it stop.
Here is a link to a picture on Coachmenrv.com. Looking at the picture the fan and air blowing is coming from the left side of the door where an arrow looking thing is pointing.
Freelander - Coachmen RV
Have also attached a picture of the section. Not sure what this is, exhaust for something? Today it is so loud I can hear it going from in the house with door shut, it goes off and on.
I'd sure appreciate any help on turning this off and finding out what it is. Thanks...
Name:	RV Exhaust.jpg
Lindan is offline   Reply With Quote
Old 01-09-2014, 06:00 PM   #2
Lloydg's Avatar
Send a message via AIM to Lloydg Send a message via MSN to Lloydg Send a message via Yahoo to Lloydg
A picture of your thermostat might help, but will assume you have a fan, A/C and heat button. There is also a fan button that has a low, high and auto setting. By setting the fan button to auto the furnace should work properly. If it is set to either hi or low, the fan will run all the time. When the furnace is switched on, the fan will keep running unless you have it set to auto. If the furnace has been on all this time, you might be out of propane too. Most RV'ers use an electric space heater to avoid using their propane. Hope this helps.
Heartland Big Country 3150RL
2013 Ford SD F250 4x4 SC; 6.2
Reese 18K Elite w/slider - Rockford, Michigan
Lloydg is offline   Reply With Quote
Old 01-09-2014, 06:13 PM   #3
Thanks for your input, I will go take a pict and post
Sorry no pict yet, having a situation not regarding the rv that I have to take care of, be back soon.
Old 01-09-2014, 10:15 PM   #4
Exclamation The fan is still running, please help...
I am back, hoping Lloyd can help or others so we can turn this thing off tonight.
Pict of thermostat attached, system is set to off, fan is on auto and the hi/lo switch is set to hi and temp set at 40*. If we switch it to heat it heats up and turns on.
There is a dial inside the rv next to the bottom step, our son-in-law said to never turn it off but didn't tell us what it was for. We did turn it off to see if it would stop the fan but it did not. Pict of dial attached.
Attached another pict of dial and a vent next to it, air is blowing out of the vent as well as the outside vent.
RV is still plugged in to 110 house and if it's unplugged the fan still goes. Propane tank was full, but we don't really care at this point. Just want to turn the fan off.
ID:	44706   Click image for larger version
ID:	44707   Click image for larger version
Old 01-09-2014, 10:21 PM   #5
TURBS's Avatar
The switch by the vent looks to be a battery disconnect switch.
TURBS
golf cart safety instructor.
Old 01-09-2014, 10:34 PM   #6
Turbs, when the rv is parked and not in use should that switch be in the off position?
Husband says if he disconnects 110 and turns that switch off the fan stops. But... that doesn't really say what the problem is. It never did it before even with the switch on.
Thx
Old 01-09-2014, 10:37 PM   #7
Ford Idaho's Avatar
TURBS
Agreed.
Set the on/auto to on.
Set AC/heat to off.
Why not turn off the battery?
I would unplug the 110 power and turn off/disconnect the battery.
Old 01-09-2014, 10:51 PM   #8
Certified Curmudgeon
LinDan,
When the fan is running with the thermostat set exactly like the picture
posted above, is there air (hot or cold) coming out of the heat ducts?
FYI, The round switch IS your house battery disconnect.
Mike Dropped
Old 01-09-2014, 10:51 PM   #9
FordIdaho we did as you said and yes the fan went off as well as lites, etc.
But when we have family stay over we turn everything back on to have lites the fan blows 24/7 even when the heat/ac switch is off.
Like I said before, this has never happened before. Do you think the thermo is broke?
ty
Old 01-09-2014, 11:01 PM   #10
Mr. Duck cold air only coming from the vent outside and inside.
Old 01-09-2014, 11:02 PM   #11
Ford Idaho's Avatar
ty
Could be.
I would put a multimeter on it.
Check the links in this thread.
Defective Furnace? - Page 2 - Forest River Forums
Tons of info on testing and replacement.
Old 01-09-2014, 11:06 PM   #12
Ford, I will read and check the furnace posts.
Thank you
Old 01-09-2014, 11:15 PM   #13
Ford Idaho's Avatar
Thank you
I have done nothing yet.
Please do post back with your findings and fix if you can.
Old 01-09-2014, 11:38 PM   #14
Mr. Ford, I think that you did, you pointed me into the direction for more info. I will post again if we fix it or find a solution.
Old 01-09-2014, 11:52 PM   #15
Denver, CO
garbonz's Avatar
The furnace is 12 volts and you can pull the fuse in the distribution center.. Same as an automotive fuse and the panel should be labelled. That way at least you can use the electrical system, while you get er fixed.
2017 Fuse 23T
Old 01-10-2014, 01:20 AM   #16
bikendan's Avatar
ty
many of us replace that crappy Dometic analog thermo, with a digital one, such as a Hunter or Honeywell thermo.
Old 01-10-2014, 06:43 AM   #17
LinDan,
You have some good responses and a direction to head in. The only thing I would add is to leave the coach plugged in to 110v with the battery disconnect on until your house batts are fully charged then turn the disconnect switch off so the vampires don't kill your batts.
Good luck with the fix and please do post what you find to be the causal factor.
Mike Dropped
Old 01-10-2014, 08:50 AM   #18
Lloydg's Avatar
It might be a defective thermostat. Being an analog thermostat with mechanical switches, there might be a defective/dirty/oxidized switch. Try moving each switch back and forth several times real fast. If this should correct the problem, a new (hopefully digital) thermostat may be called for.
Old 01-10-2014, 10:07 AM   #19
jonrjen's Avatar
Here is my suggestion for what it's worth. Your Screen name says your location is So Cal., if you would care to narrow down your location maybe a member here would be willing to stop by and give you a refresher course on how things work, where various controls are located, and share a few time learned educational experiences with you. Most RV folks are more then welcome to help one another out.
Just a thought,
2018 Berkshire XL 40B
Past RVs: National Pacifica 40', Kenworth T300 Toterhome, Jayco Class C 32'. American Eagle 40',
American Eagle 40', Bounder 38' tag axle
jonrjen is offline   Reply With Quote
Old 01-10-2014, 07:49 PM   #20
litgrep's Avatar
If you turn the propane on and bump the thermostat up to about 70: does the heat come on? If it does, flip the furnace switch from off to furnace then back to off. Turn the thermostat back down all the way. The heater will run until cool down then should turn off. If it doesn't, bad thermostat switch. Pull fuse to turn off and have the thermostat fixed or replace. There are several threads on the forum replacing the thermostats with digital ones from Home Depot.
2013 Salem Hemisphere 286 RLT
2009 Silverado 2500HD
litgrep is offline   Reply With Quote
fan
