Old 08-22-2019, 09:08 PM   #1
Ford E450 Chassis Powertrain Control Module Failure
We bought a 2019 Leprechaun 319mb which is on the Ford E450 chassis this past February. We have made 4 trips in it so far. It still has less than 5,000 miles on it. Unfortunately when returning from our last trip the engine shut down at a traffic light when we got of the expressway to get dinner. Had to have it towed to a local Ford dealer in (Brighton Ford). They diagnosed it as a Powertrain Control Module (PCM) failure, and replaced the module. Just picked it up Monday and it started up and ran the hour home with no problems. The issue I have is that the tech at the dealership couldn't really give me a reason as to why the PCM failed, and now in the back of my mind I can't help but wonder what is wrong with the coach that caused it. Has anyone had a issue with the PCM or any other control modules in their newer coach? Or does anyone have an idea of what could have caused the PCM to fail?
Thanks, Mike in MI
MI-Camper is offline   Reply With Quote
Old 08-22-2019, 10:15 PM   #2
Blackrock's Avatar
Worked as a mechanic for 40+ years and through training and experience found that major component failure early in a vehicles life is usually caused by a cold solder joint somewhere on a board.
Next up was pin pushed back in a terminal socket followed by corrosion in a plug or socket.
2016 RAM 1500 - 2016 Keystone Laredo 265SRK
The road goes on forever and the party never ends.
Blackrock is offline   Reply With Quote
Old 08-27-2019, 10:36 AM   #3
Some parts out of thousands are not going to perform well. It the nature of the beast. I bought a brand new Patriot, the dealer had to replaced the front disk brakes during the first 2,000 miles. No problems after that. It happens.
2017 Leprechaun 311 FS
Jeep Patriot and Cherokee as toad.
Enjoying retirement.
jonwisconsin is offline   Reply With Quote
Old 08-29-2019, 06:52 PM   #4
World Wide Wanderer
wahoonc's Avatar
I would say it just occasionally happens. A bad part slipped through. I asked my Ford dealer how many they have replaced and said they average 2-3 a year across all the vehicle lines. So not a super common issue.
Aaron
Aaron & Rhonda
wahoonc & Airangel60
2016 Coachmen Concord 300DS
2015 Fusion Hybrid following along
wahoonc is offline   Reply With Quote
ford, power
