Old 03-02-2020, 07:58 AM   #1
Freelander 27QB Dinette Replacement - Pics
We have started the process of replacing our dinette and jackknife sofa. This weekend was the demolition and some movement. Sharing pictures and comments...
We removed the dinette and the sofa. We moved the forward bench to replace the sofa. We removed the second bench and then taped out the dimensions of the 53" dual recliner, both closed and opened so we can see how much space we have.
When the recliner is closed, we will have ample walking room. When open, we can get by but it will be tight. We figure that we won't be doing too much walking while the recliner is open.
We're stuck with that stupid junction box in the middle of the floor, as there is a hole in the floor feeding the AC to the galley. Would love to ask the engineer what the thought process was with THAT!
Nate Ravid
2018 Freelander 27QB
nravid is offline   Reply With Quote
Old 03-02-2020, 08:44 AM   #2
Nate, I doubt anyone who build RVs like ours thinks about someone remodeling them. So, they engineer it with the mindset that if you can't see it, it's okay.
That's why when I've done maintenance or remodels, I always find screws, boards, screw drivers (yes!), PVC chunks, etc....underneath and behind things never designed to be disturbed.
Searching for TV/cable splitters has always left me wondering about what else I can't see that would probably scare me.
Jim
2018 Coachmen Freelander 27QB
CC38EL is online now   Reply With Quote
Old 03-02-2020, 09:04 AM   #3
Jim,
Even my wife stated that this was likely a "4:45 on a Friday" build!
Stripped screwheads all over the place, mismatched screws (1", 1.5", 2" - Meh! They're all the same!)...
I just would love to know why they couldn't put the AC feed 12 inches back UNDER the galley! I'm sure there is a logical explanation (I hope!)...
Nonetheless, we're having a good time doing the renovations, and making the rig our own!
Nate Ravid
Old 03-03-2020, 11:29 AM   #4
I guess the pics never got attached. Let me try again...
Dinette Removed (4x4 Junction box on floor)
Name:	Dinette Removed-2.jpg
Front Dinette bench moved to passenger side to replace Sofa. Cut out for the Exterior Entertainment Center box.
Name:	Inside Bench Around Box.jpg
Bench closed - About 14 inches left for storage near door.
Name:	Bench Closed with Cushions-2.jpg
Tape indicating a 53" Dual-Recliner love seat in closed position. We ultimately opted for the 67" sofa with the console insert.
Name:	Recliner Taped-Closed.jpg
Tape indicating the furthest length of the extended recliners - 64"
Name:	Recliner Taped-Open.jpg
Nate Ravid
Old 03-03-2020, 04:25 PM   #5
I am almost positive that junction box comes from your generator and goes to the electrical panel. You could relocate that junction box into the cabinet or under the floor with a watertight box. It would require you to drill a new hole from under.
Interested in seeing the after pictures.
markb422 is offline   Reply With Quote
Old 03-03-2020, 04:34 PM   #6
Mark,
So if the wires coming up through the floor are coming from the generator, and the other side is going to the galley, is that where it joins the shoreline power to the electrical panel?
Since the recliner will be mounted over the junction box, we have no specific reason to move it, other than its in a stupid place!
But, again, why didn't Coachmen put it under the galley (or closer to the shoreline) in the first place?
I know. sometimes we ask questions that need no answer!
Nate Ravid
Old 03-03-2020, 04:51 PM   #7
The wire actually goes to a receptacle in the shore power compartment. Because there is no transfer switch you have to plug the shore power cord into the receptacle to get power to the panel. And good question about the location. Coachmen would have to answer that one.
Old 03-08-2020, 12:27 PM   #8
How is the remodel going? Got your stuff in yet? Pics?
Jim
Old 03-08-2020, 07:25 PM   #9
Recliners are In!
Jim,
Today was recliner day. We got the RecPro Charles 67" with the Console installed. We went with Putty Leather for the lighter color.
This is the recliner closed:
Name:	Recliner Closed.jpg
This is the first detente:
Name:	Recliner First Detente.jpg
And this is fully extended (or "Sleep Mode Activated"):
Name:	Recliner Full Detent.jpg
We also installed the second MaxxFan over the recliners. The third one will go in the bathroom next weekend.
We are still looking for options for Lagun table mounts for the Dinette Bench. Something removable when not in use.
Nate Ravid
Old 03-08-2020, 07:38 PM   #10
That is nice. I felt relaxed just looking at the pictures.
Great job.
Jim
Old 05-15-2020, 01:19 PM   #11
We replaced the sofa with these.
Old 05-17-2020, 12:04 PM   #12
Jim,
Those recliners look great, and swivel, too, I guess?
Nate Ravid
Old 05-17-2020, 05:13 PM   #13
Yes....and they allow you to get your legs up most of the way. The dinette will stop your feet...but you can still use the leg lift.
Jim
replacement
