"Most" RV furnaces are Suburban, but not all. If your thermostat says Suburban on it, then your furnace is almost certainly a Suburban.
If you can find your furnace , you can verify the manufacturer. To find it, go out side and find the intake/exhaust port. Looks like this:
Then go inside to the same location. The furnace is usually under a dinette seat, maybe in a closet, sometimes under the sink.
Under the assumption it's a Suburban, I've attached a manual that covers a lot of their models.
