02-08-2022, 12:20 PM
Irish55
Generator Clicking 2004 Coachmen Concord
Hey I am new to the forum and a new rv owner. Purchased a 2004 Coachmen Concord in October 2021. We decide to remodel the inside before taking a trip. We had started the Onan generator 30 to 40 times while we were working on the inside. We took our frst trip New Years weekend. Started the generator when we fiisrt got there to set things up. The next morning when we tried starting the genertor it would just click and the lights would dim. The coach battery was new, but i went ahead and replaced it anyway. Since then I have installed a new complete power center. I am looking for some help!
02-08-2022, 12:57 PM
Georgia Rally Coordinator
Welcome to the forum. Post your question under the sub thread Coachman. Lots of knowledgeable folks there to help ya. Later RJD
2018 Dodge Ram 2500 6.4 3:73 gearing. Traded 2015 Chevy 2500 6.0, 4:10
Traded 2015 30WRLIKS V-Lite
Days camped 2019 62
02-08-2022, 01:12 PM
Moved to the Coachmen Motorhomes sub-forum.
02-12-2022, 12:18 AM
Most gasoline generators will not use the last 1/4 tank of gasoline in order to prevent you from being stranded. How much gasoline is in the tank?
02-12-2022, 06:34 AM
Calvin, yup that be my answer also. about the 1/4 tank fuel. Wonder if unit has a Mom switch, i think thats what they call it, uses both house/coach batteries to start gen/eng.
Abe Arctic Wolf 2021 29IRl
2017 Titan XD 5.0 Diesel 2018 Indian Roadmaster
Disabled Vet, IT Guy SW Fla.
02-12-2022, 07:51 AM
Bad starter??
Larry
2014 Ram 3500 Dually 4x4 6.7 Cummins
2017 Sandpiper 378FB
02-12-2022, 08:16 AM
Usually a click is a relay clicking. Of course after the relay clicks it is supposed to be sending a signal downstream to what it is controlling say a starter motor. Find the relay. Measure voltage into relay and then out of relay.
Starter motors for these small motors are usually centrifugal motors which means first the motor spins and then it engages. That is different from a car starter which usually uses a plunger to engage and then spin.
If you have 12Volts to starter motor pull it out. You can hook it up across your battery and see if it spins. Mostly the motors don't fail but the mechanics do which could include just putting oil on the shaft. A return spring can be broken a retaining clip can be broken or even the motor could be bad. I would bet the motor is just all gunked up or that the relay is bad.
02-12-2022, 09:56 AM
Irish55
Thanks for the advice. I was able to get the generator to turn over by putting a socket on the crankshaft and turning the crankshaft. Now the generator will turn over but will not run. I changed the spark plug but that did not help. The only I can get the generator to run is with starting fluid, but it will only run for a few seconds.
02-12-2022, 10:05 AM
The fact that you are able to start it and it runs on the starting fluid leads me to believe the battery power is getting to it but it's not getting gas. Have you verified gas flow out of the fuel pump?
2018 Georgetown XL 377TS
2020 Jeep Gladiator "Toad"
CAMPING (n. CAM-ping) - When you walk the dog in your pajamas with a cup of coffee in one hand and a bag of dog poop in the other while striking up a conversation with total strangers.
02-12-2022, 10:38 AM
Kanadian Kamper
Post #4 asked about how much fuel you have in the tank of your motorhome and you haven’t responded. Your symptoms still indicate it’s a question that needs an answer, especially when you state it runs on a small supply of starting fluid.
Ken and Terry
02-12-2022, 10:46 AM
The mice are a hole in the fuel line in my old rv. Same symptops, would run fine if you stuck the fuel line in a can of gas.
TT - 2021 Rockwood 2608BS
TV - 2020 F-250 XLT 4WD SRW 6.2L gas
02-13-2022, 12:22 AM
Apparently he enjoys trying the more difficult things first.
02-13-2022, 12:56 PM
Check oil level and read fault code output if any
02-13-2022, 03:58 PM
Irish55
I know there is gas going into the carburetor
02-13-2022, 03:59 PM
Irish55
Full tank of gas
02-13-2022, 04:01 PM
Is this the 5500 model ?
02-14-2022, 03:37 PM
Irish55
It is a 4000
02-14-2022, 03:57 PM
Fuel filters and a general clean? Small, hard working gas engines like gensets can be sensitive to fouling.
2022 Rockwood Roo 235S
15kBTU AC; 12v fridge; 1kW roof-mounted solar panels; 80 amp MPPT charge controller; 3,500w pure sine wave inverter; 30a automatic transfer switch; MicroAir EasyStart, 600ah Chins LiFePo; Honda EU2200i (with Hutch Mountain propane conversion kit) gathering dust in the storage unit.
02-14-2022, 04:31 PM
Irish 55 - get your model number and down load the service manual. May help
02-15-2022, 12:13 PM
Irish55
