Old 03-23-2020, 07:58 PM   #1
Grey tank vent leak, 2014 Mirada 29ds
Did anyone experienced a leak in the wet bay compartment from their gray tank when it gets full, I suspect it is the tank vent but I dont know where to look , is there any access panel that I can remove to check that vent connection to the tank? Thanks
Hkhadra is offline   Reply With Quote
Old 03-24-2020, 08:38 AM   #2
SeaDog's Avatar
overfilling is never good regardless which tank it is but I"m sure you know this. It may not be the vent could be the discharge piping for sinks, shower etc. check the area above the tank and below where the vent stack comes into the rig you may have to cut an access hole to inspect the fittings. good luck let the forum know what you find.
Retired Navy
2016 Flagstaff 26 FKWS
Old 03-24-2020, 04:30 PM   #3
I am bringing the rv next week and I will tinker with it, I post some pictures if I find any thing. Thanks
Old 03-25-2020, 11:26 AM   #4
The tanks will be close to where they drain. Unfortunately, in a wet panel area, it most likely will be behind the panel you look at when you open the wet area.
They literally build the RV around those tanks, drill holes in floors, route pipes to the tanks, seal them and then lay the floor down.
Major PITA!
You might be lucky enough to see inside by pulling an access panel to the back part of your shower. I'm not totally familiar with your specific coach, but the pictures of it I've looked at would put your tanks under the shower area.
Jim
2018 Coachmen Freelander 27QB
CC38EL is offline   Reply With Quote
Old 03-25-2020, 11:55 AM   #5
Thank you for reply, I believe you are right, someone on the IRV2 forum has the same RV and the same problem, he may send some pictures to help , I will update here also. For the wet bay panel , I am taking that off anyway, I took it off before so I am familiar with that area but now I am changing all the connections, new pump and adding accumulater. This is the reason why I am trying to fix the grey tank problem, I want to get done with wet bay issues once!
Major PITA!
Old 03-29-2020, 11:44 PM   #6
We found the problem, it is the thread going into the gray tank was broken. It seems this is a common problem that many coachmen 29ds suffered from.Click image for larger version
ID:	225985Click image for larger version
ID:	225986Click image for larger version
ID:	225987Click image for larger version
Old 03-30-2020, 08:39 AM   #7
That looks like some significant digging was required to get to that pipe. Glad you found it.
Much damage underneath?
Jim
Old 03-30-2020, 08:46 AM   #8
Thankfully no damage, the leak between the fitting and grey tank was leaking above the tank and to the outside of the RV . What helped is coachmen used metal sheet between the tank and the floor. I believe the whole belly of our mirada is covered with that sheet metal.
2014, leak, tank, vent
