Old 03-25-2020, 03:59 PM   #1
Headlights
I have a 2015 coachmen Persuit KB27. The low beam are terrible. Can they be replaced?
Therig2 is offline   Reply With Quote
Old 03-25-2020, 10:18 PM   #2
When you say 'terrible' what do you mean? Terrible brightness? Terrible aim? Something else?
Most class A headlights started life as something else. On my former 2002 Ultimate Advantage, the headlights were from a 1997 Mercury. Strange but true.
So yes they can be replaced....but it may be difficult to find an exact fit for the custom hole that your rig has.
They can be aimed better and you can replace the bulb with a brighter one. If you can get to your bulb and find out its type, an internet search will point you to a better replacement.
Jim
2018 Coachmen Freelander 27QB
CC38EL is offline   Reply With Quote
Old 03-26-2020, 09:13 AM   #3
Thank you for your reply, yeah they’re just not very bright on low. I can barely see the road. They have been adjusted but that didn’t help much. I guess I’ll remove one and see if I can replace them. Thanks again
Old 03-26-2020, 09:24 AM   #4
Jim34RL's Avatar
You might be able to install LED lights if you have, the bulb number and contact one of the auxiliary equipment sellers on the web. Another thing that can be done is installing fog lamps but use a clear bulb. You can than run these as driving lights which can help you see better in low light conditions. Why fog lamps the light pattern is disperse low and towards the ground, which will help you see the road better.
Just another thought!
Jim W.
2016 34RL CC; 2008 Ram Mega Cab 2500HD, 6.7L, 68RFE 6 speed, 4X4, Smarty S67, TDR 135K+miles
Old 03-26-2020, 10:04 AM   #5
Kanadian Kamper
kenandterry's Avatar
....or order the “Retirement 101” option.
Retirees don’t need to drive at night.
Ken and Terry
2010 Georgetown 330TS being pushed by our
2017 GMC Terrain toad (4 wheels down)
kenandterry is offline   Reply With Quote
light
