My equalizer system is leaking oil at motor,dripping off end.
(see picture ) I think it only leaks when running pump motor. Any one else have this problem ,cant find any info on seals or parts break down. Out of warranty an 12 hours from dealer. rest of pump assy is clean .just dripping off end of motor,has not rely using any oil .
Carl & Bette
2018 Leprechaun
NEW YORK
I never seen that problem before, but I would think that there is a “O” ring under the cap, also it looks like 2 bolts if I’m seeing it correctly, did you try and tighten the bolts? I’m just guessing here, what system is that on? Did you call the company , maybe they can shed some light on it. Good luck
Call them to find out the hole pump, motor has to be replaced. Seal is not service able.. going to keep and eye on it for a while and my take it apart when we get back in spring ..
Carl & Bette
2018 Leprechaun
NEW YORK
