Old 08-31-2020, 01:49 PM   #1
nvs4602's Avatar
Hidden fuses on e450 class C
I found 2 hidden fuses under the driver side door step. On our 2017 311FS Class C on E450 chassis. I emailed Jason Johnson at Coachmen to find out what they are for, and here is his response.
They are 5 amp fuses. One is for your heated mirrors and the other one is for the house battery charge while driving down the road… If your house battery is not charging off the alternator while driving this fuse is normally blown….
Jason J. Johnson
Service & Warranty Representative
Coachmen Class C Division of Forest River, Inc
nvs4602 is offline   Reply With Quote
Old 08-31-2020, 02:46 PM   #2
nvs4602's Avatar
Has anyone else found hidden fuses like this?
Old 08-31-2020, 03:46 PM   #3
Usually Confused Member
emm-dee's Avatar
So why were you looking in that area? Does the fascia piece come off easily?
2018 Forester 3051S (aka Clyde)
2015 Wrangler Toad (aka Bonnie)
At some point during every day you suddenly realize nothing else productive is going to happen the rest of that day. For me, it usually occurs around 9 am.
Old 08-31-2020, 03:59 PM   #4
nvs4602's Avatar
I was installing our dash camera and was hardwiring into the fuse box in the engine compartment. So I was removing the side kick panel around the emergency brake. The plastic panel over the step on mine just lifts right up, so it's real easy to remove.
Old 08-31-2020, 04:14 PM   #5
emm-dee's Avatar
Thanks. That’s good info to know.
Old 09-01-2020, 10:10 PM   #6
HerveVR's Avatar
What a silly idea to «hide» fuses under doorstep !
Fuses are a safety devices and should be at get-at-able location. Desing ?
I'll have a peek at my RV.
2012 Lexington 265DS
HerveVR is offline   Reply With Quote
Old 09-02-2020, 01:34 PM   #7
Does anyone know where the fuses are for the two maxxair fans in my leprechaun? I'm at my wits end. neither unit has power to them, and they were working fine. I have to believe its a fuse or circuit breaker. Any help would be appreciated.
liftone is offline   Reply With Quote
Old 09-02-2020, 04:51 PM   #8
nvs4602's Avatar
Check crimped wire terminals too. I changed out 2 light switches to dimmer switches and had 3 wires the crimped terminal just fell off. Now my awning is acting up grabbed a bunch of wires under the dinette and it started working again. So I'm sure I'll find the same problem.
Old 10-22-2020, 11:41 PM   #9
nvs4602's Avatar
Fuses are in strange location.
class c, fuse
