Old 09-27-2019, 04:24 PM   #1
Inverter
2017 Mirada select with 22,000 miles. Tech says inverter needs to be replaced as it is not communicating and fault reading says bridge problems. Is this unusual? Thank you.
mtlady12 is offline   Reply With Quote
Old 09-27-2019, 09:27 PM   #2
Sounds weird with only 2 yrs. of service.
2017 Leprechaun 311 FS
Jeep Patriot and Cherokee as toad.
Enjoying retirement.
jonwisconsin is offline   Reply With Quote
Old 09-28-2019, 07:54 AM   #3
far north Alabama
formerFR's Avatar
without knowing what year/make/brand/model/size your inverter is, it's hard to give you any advice. Also, do you have a remote control panel, or just the inverter itself.
Does the inverter power the fridge, only? or is it wired into your Main panel where it powers some or all of your outlets, also?
Does it have an AGS model/function to start your generator automatically when your battery levels get low, etc? Sometimes this 'communications' problem is between the Inverter controller and the AGS module.
The Turners
'14 Thor Palazzo 33.3 compact diesel
KingTailgater2 Dish, 100w/5amps roof SOLAR, BlueOx, 100,000+mi since '14... US, Alaska, and Canada... GA, NC, now N AL : )
formerFR is offline   Reply With Quote
Old 10-01-2019, 11:27 AM   #4
Although I know nothing about inverters except I love my Magnum in my Sportscoach since purchasing in May, two years old seems odd. Second opinions by a mechanic you trust wouldn't hurt vs. a tech at a RV dealer.
sherman12 and The Fabulous Miss Barb
2014 SportsCoach Cross Country 360DL DP
Former 2011 Georgetown 330TS
Kia Sportage on MasterTow Dolly
sherman12 is offline   Reply With Quote
inverter
