Originally Posted by Stearn
Took shake down trip towing our Equinox on a tow dolly. It seemed that when I was in trailer tow mode the rpms went up. We have the 260DS Leprechaun with chev 6.0 . Would appreciate some education on best way for towing? We were mostly on two lane hwy 55 mph speed limit , most of the time with curves the speed was more like 50, 1500 RPM without the trailer assist on. Trailer assist on RPM went up a couple hundred ?? Our last mh was a class a 8.1 with Allison 6 speed it did not have the tow assist.
Necessary/required?
Depends on the load versus tow vehicle ratio. The instructions that came with my Titan indicated it should always be engaged when the weight of the towed vehicle passed a certain percentage of the Titan's weight.
I have a separate temperature gauge on my tranny, one that reads actual temp in degrees F, and when I forget to engage the "Tow/Haul" mode the temp climbs rather rapidly. I also notice that the throttle isn't as respinsive as the tranny shifts into higher gears than are desired for the speed/load.
It's just like when towing with a standard transmission. You leave the tranny in the same gear longer before upshifting. Ditto for what happens in your auto tranny. As for using the "Overdrive" (top gear) I go ahead and use it when I am on a long flat or slightly downhill stretch of road or when I have a stiff tail wind. I keep an eye on temp and downshift to the direct gear. Helps a little with mileage but not a good idea if your tranny temp rises too high. (mine has an extra Long (brand) plate type tranny cooler so my transmission temp averages 160 degrees or less, even when the outside temp is considerably higher.)
2023 f-150 SCREW XLT 3.5 Ecoboost (The result of a $68,000 oil change
