Jacks are stuck in up position. In auto mode air will dump but jacks do not come down . Same in man mode no movement of jacks. Checked 10amp fuse good reservoir fluid good. Auto light stays lit and the right button stays lit.
Not familiar with your particular system, but I would check the manual and see if there is some way to do a hard reset on the system. On my BigFoot, you unplug the controller and unplug the power from the brain box. Then wait a few minutes and hook it all back up.
