The LED clearance light that has the rear camera attached to it , is almost burned out. Only two lights left. I would like to have the replacement before I remove it.
I’m hoping someone will know what I might need. My thought is that the lights may be separate from the lens???
The closest dealer is over an hour away, trying to avoid the drive.
2019 Leprechaun 26 DSC
Do you have a picture of it?
I had a couple of front marker lights go out on my 2016 Concord, the dealer wanted somewhere around $30 each for them. I found the OEM online and got them for ~$8 each. I ordered plenty of extras!
I have been looking ,but so far not finding anything. I did call coachman parts and , was told part is $160.00. I still have some light . Will keep looking for aftermarket part . Maybe by summer I will find something.
. The problem is the light that needs replacing has a camera molded to it. Etrailer have some that looks close . But without the camera. Need the camera.
I may just have to bite the bullet, , but first be sure there is nothing else to replace it.
