Old 01-22-2019, 12:52 PM   #1
Carl17's Avatar
Exclamation Leprechaun 311fs low points
just found low point drains. under center dinette seat.
plus one under bed.
new about bed but found others by accident. not IN Manual.
2019 311fs
ID:	195146   Click image for larger version
ID:	195147   Click image for larger version
Carl & Bette
2018 Leprechaun
NEW YORK
Carl17 is offline   Reply With Quote
Old 01-22-2019, 11:10 PM   #2
Yeah! They are there. I found mine two as I was looking for a tiny leak from the water heater. Manuals on these things are not helpful. They are generic.
2017 Leprechaun 311 FS
Jeep Patriot and Cherokee as toad.
Enjoying retirement.
jonwisconsin is offline   Reply With Quote
Old 06-04-2019, 09:00 PM   #3
I ran across this thread while looking for past Leprechaun 311FS comments. Thank you for your info, Carl17 and jonwisconsin.
FYI, we also had a leak near the water heater after we connected to a campground high pressure rural water system on our maiden trip. The extra pressure caused a loose, screw-on hose connection to leak and some minimal water trickled out from under our dinette overnight. Since the leak was so slow, it took a few minutes to pin-point the drip and tighten the coupling. We were able to quickly dry things out without damage and we now use a low-cost pre-set pressure regulator input to ease the strain just in case.
If others find the same leak problem, I might suspect that the connection easily comes loose or otherwise leaks and then upgrade the fitting. I did find the low point dinette drains mentioned, but did not use them because the access covers (seats) were screwed down on ours and I use the blow-out method to winterize which makes this under-dinette chore unnecessary.
For winterization, I drained the fresh water tank from under the bed using that low-point but accessed it by unscrewing the large access cover (top bed platform) and lifting the obscure tiny valve handle/plug. Since the handle/plug tends to accidentally lift all the way out, I think I will always open the bed for this service to see better, instead of reaching in the small, dark vent-like access port on the side of the bed platform.
All-in-all, the blow-out method worked quite well to winterize after draining the water heater, fresh water tank and running the pump dry. I add RV antifreeze to the drain traps and make sure no liquid remains pooled in any waste pipes.
Wes
2019 Leprechaun 311FS
Wes, Linda & Quincy (std. Brown Poodle)
Wes Tausend is offline   Reply With Quote
Old 06-04-2019, 10:56 PM   #4
Wes, I found a leak like you coming from the base of the dinette. After removing the seats and the plywood base, I found that there was a small leak in the water heater. I had to disconnect the inlet and put some sealer on the connection. This took care of it. Just in case it happens in yours.
