Old 01-22-2020, 03:56 PM   #1
Low Point for drains Leprechaun 260 RS
After perusing the forum, I found that my 2019 Leprechaun 260 RS low point drain, for draining freshwater was behind the black 6x5 panel on the left wall of driver side large compartment. It was even marked but I found electrical wiring, not drain lines. Expecting a petcock but not this. Newbie is in over his head for what I thought would be a simple and easy task. Manuals are non-existent and my walk thru was all use, not maintenance. Any suggestions,are greatly appreciated. I can't imagine pulling out wiring to drain....Click image for larger version
RicknHB is offline   Reply With Quote
Old 01-23-2020, 12:46 PM   #2
SeaDog's Avatar
does seem like a kind of dumb place to put the drains did you happen to look under the coach adjacent to this sticker? good luck how ever you proceed.
Retired Navy
2016 Flagstaff 26 FKWS
Old 05-25-2020, 03:30 PM   #3
If I stick my phone in the cutout and look to the right, here are the 3 freshwater drain lines, hot, cold and tank. You pull the black tee handles up to drain.Click image for larger version
Old 05-26-2020, 07:23 AM   #4
Why not cut the access hole bigger, and make a new cover? Your drains should be on the right side of your opening......Bruce
Bruce and Sandy
2007 Scepter 42PDQ--Sold
2018 Coachmen Leprechaun 26DS Chevy
waco kid is offline   Reply With Quote
Old 05-28-2020, 10:07 PM   #5
Stearn's Avatar
I took out the panels in basement storage that goes under the bed. I bought 1/4 “ plywood, then cut to fit behind the original covering. I did not have access to the fresh water pump, made a door for easy access to the pump. The drains three of them had an access door . Drains are in front of fresh water tank . With the walls stronger I hung a couple Rectangular baskets , and a bracket to hang my hose , and 30 amp cord. The drains are still a stretch to reach.
Stearn is offline   Reply With Quote
drain
