Old 05-12-2020, 08:38 PM   #1
Metal coil antenna
Our RV has one of the metal coil antennas like 2' long on top. We put a cover on the RV and it ripped a hole through the cover. When I went up to look, the pressure of the cover making the antenna bend down looks like it's pulling up at the base with the sealant.
1) any good ways to solve this? Can you remove the long antenna part when you want the cover?
2) Ang good replacements with shorter antenna?
3) would it be a good idea to remove that antenna and seal over with lap sealant? We most likely will just use our phones for music.
Dano9258 is offline   Reply With Quote
Old 05-12-2020, 08:45 PM   #2
Just as confused as you
Scrapper's Avatar
Usually radio antennas with the coil spring has a ball at the base with a screw you can loosen to lay it down. Sometimes they do have the upper whip you can unscrew with pliers.
Name:	Ball Spring Radio Antenna.jpg
Richard & Jill
Camping since 1989, seasonal since 2000
The Faster I Go, The Behinder I Get.
Scrapper is online now   Reply With Quote
Old 05-13-2020, 12:23 PM   #3
If not using the radio I'd just remove the adjustment screw and put the upper part of the antenna, spring and all, in "storage". If you ever trade or sell just reinstall.
"A wise man can change his mind. A fool never will."
"Sometimes you're the dog, sometimes you're the tree"
2004 Nissan Titan
Old 05-13-2020, 02:07 PM   #4
bikendan's Avatar
Exactly, my previous HTT had this antenna and I simply loosened the ball set screw and folded the antenna flat. Then I put the cover over the trailer.
Equalizer WDH
antenna
