Originally Posted by Henry Barnes
No info about you window but I do about the 10 foot drop. My window on my Coachmen class c did not come out but did hang on your back as you tried to exit the window so I held it open all the way and drilled a hole in frame and put a pin in to hold it open. Next I got the back wall drawing from FR as to where the studs were located and install a fire escape latter under the window. At 70 years old If the smoke & fire didn’t get me the 10 foot drop would
Hank
I've thought about this, but don't know if I would have the presence of mind in an emergency. The exit window is over the bed. The intuitive way to exit is head first, but it seems like the best way to exit is feet first, face down. Squiggle out until you can bend at the hips. Continue, and as your torso exits, grasp the bottom edge of the window frame with both hands. Hold on until your arms are fully extended. Then release. At this point your feet will only be 2-3 feet from the ground. At 75 years of age, I believe I can manage this. I will try it when I have the opportunity. In fact, periodic fire drills would be a good practice, especially for family campers.;
