Old 09-08-2019, 12:23 PM   #1
meg
Mirada howling noise
We have a 2011 Mirada. While driving it is making a horrible howling noise over the drivers side of the motor home.It seems to be coming from the roof. We were just at the Coachmen factory and they couldn't seem to fix it. We have had every thing caulked. Any one else have this problem? When we get a head wind it is really loud.
meg is offline   Reply With Quote
Old 09-12-2019, 02:14 PM   #2
My 2017 Mirada Select LS hows also, and tracked it down to two different causes. One major howl is coming from the frame-less windows, and the other was the antenna whip on the roof above the front cab. No fixes for these.
Mirada_Eric is offline   Reply With Quote
Old 09-13-2019, 09:25 AM   #3
Check to make sure the seal around the windshield in the corner is solid. I had a similar issue.
manderson2228 is offline   Reply With Quote
Old 09-13-2019, 06:19 PM   #4
We have a coachmen pursuit and it does the same thing. I was thinking it was the mirror as it only happens when its windy. I think it gets a harmonic vibration causing it to make a growling noise.. But I haven't ben able to confirm it yet.
DaveandChris is offline   Reply With Quote
Old 03-14-2020, 01:37 AM   #5
sa1jzm's Avatar
Do you have a Maxxair Fan Cover? I do on my Freelander and makes a howling / rattle with strong headwinds. They tried tightening it, but... still does it
sa1jzm is offline   Reply With Quote
noise
