Old 02-22-2019, 01:36 PM   #1
Cool no water out of hot side
I'm a first time motorhome user and just purchased a 2015 Coachmen Leprechaun 220QB. I've pretty much figured everything out, but when I fill the fresh water tank and the water pump is on, water will come out of the cold water side, but nothing, hot or cold comes out the hot side.
Any help would be greatly appreciated. Thanks
vciriello is offline   Reply With Quote
Old 02-22-2019, 01:51 PM   #2
woodyrock1's Avatar
Sounds as if the hot water bypass valve is shut.
05 Ram 3500 Cummins Dually
14 8280WS Rockwood Sig. Ultra Lite
Prodigy 3 brake Controller
TST 507 TPMS
2017 = 30 nights /
2018 = 7 nights
woodyrock1 is offline   Reply With Quote
Old 02-22-2019, 01:58 PM   #3
I thought that might be the case but I havenít found it yet. Is it under the bed? Thanks
Old 02-22-2019, 03:18 PM   #4
Sounds like the by pass valve has been open not allowing hot water to run. The hot valve and bypass one are next to the water heater. That’s where mine are. Good luck
2017 Leprechaun 311 FS
Jeep Patriot and Cherokee as toad.
Enjoying retirement.
jonwisconsin is offline   Reply With Quote
Old 02-22-2019, 03:33 PM   #5
Even with the bypass valves turned, you should still get something out of the hot side. Makes me wonder if there's a blockage somewhere. Is this happening at all your faucets?
Iwritecode is offline   Reply With Quote
Old 02-22-2019, 03:34 PM   #6
Make sure you don't turn on the water heater until it is filled with water.
2018 Ram 2500 Tradesman, CTD/CC/SB/4X4/Equalizer WDH
2019 Forest River Surveyor Legend 19BHLE
upflying is offline   Reply With Quote
Old 02-22-2019, 05:55 PM   #7
woodyrock1's Avatar
I am not familiar with your rig. Is there a winterization connection? If so check to see if that valve is in-line and out of bypass mode.
TST 507 TPMS
2017 = 30 nights /
2018 = 7 nights
Old 02-22-2019, 07:19 PM   #8
bubbles's Avatar
Sounds to me like by-pass valve is in normal position. It could be that the water heater inlet valve is in winterized position or the water heater outlet valve is in winterized position or both of those valves are in the winterized position. There could also be a blockage I suppose.
Old 02-22-2019, 07:32 PM   #9
I suggest going on a fact finding mission.
On the outside of the camper, are you getting hit water out of the overflow valve on the WH?
On the other side of the WH, how many valves do you have? What are their positions? A pic would help.
And as others have asked, are you getting hot water at any faucet?
Skip12 is offline   Reply With Quote
Old 02-22-2019, 07:49 PM   #10
This from the OP
Old 02-23-2019, 10:36 AM   #11
Originally Posted by cavie View Post
This from the OP
No, Iím not getting hot water from any of the faucets or showers (inside or outside)
Old 02-23-2019, 11:01 AM   #12
Have you checked the bypass valves? Do you know where they are?
Start there for now.
Check out this thread for information on the valves.
http://www.forestriverforums.com/for...st-103381.html
Old 02-23-2019, 11:14 AM   #13
Are you getting NO WATER or no HOT water? We need to be clear on this!!
Old 02-23-2019, 11:18 AM   #14
Mr. Dan's Avatar
Can you find your water heater? Your valves are either behind or very near your water heater OR they're plumbed into your water connection panel outside your unit.
SEARCH is your friend!
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 = 111/'19 = 86/'20 = 26; booked = 42
Old 02-23-2019, 11:34 AM   #15
As Mr. Dan said, your hot water valves will be behind your water heater. I've attached a pic of the many ways the manufacturers have come up with to plumb the inlet/outlet/bypass valves. Hope it helps you.
All valves are shown in the normal, NOT-winterized, position.
2011 Traverse LT, 3.6L, FWD
Old 02-23-2019, 03:29 PM   #16
If you are getting no hot water at all, it is most likely the check valve on the discharge of the water heater. Relatively cheap, and easy to change if you can get to the back of the water heater.
Cathcartww is offline   Reply With Quote
Old 02-23-2019, 03:52 PM   #17
Not everyone has a check valve. In fact, I'd say "most" don't.
Old 02-23-2019, 04:19 PM   #18
BobHanke's Avatar
As Skip12 suggested, trip the pressure safety valve on the outside to see if the tank is full. Do this carefully as water could be painfully hot.
"Lurch" = Georgetown 2011 330TS
Toad = Jeep 2016 Cherokee
Pilot = Bob
Navigator = Xiangbing
Crew = Radar, NiuNiu & NaNa
BobHanke is offline   Reply With Quote
Old 02-23-2019, 06:47 PM   #19
Flybob's Avatar
If the WH is empty as in winterized, it will take several minutes before water comes out as the WH needs to fill before it will allow water into the lines.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 02-23-2019, 06:47 PM   #20
Tom48's Avatar
Open a hot water faucet. with the water pump on there could be a near silent flow of air coming out and that would be normal for the WH tank filling. Mine blows a lot of air before the faucet gets water when the tank has been bled down.
Pull the pressure relief tab on the overflow at the top outside of the water heater. IF you have pressure in the HW tank there will be a blast of water, or air followed by water. Be careful if you have heated the tank it will be HOT WATER
And as always, when you solve this problem, please post and tell us all what was wrong. No matter how obvious or difficult it is, we all learn from these posts. Especially good to learn if we understood the problem and had the answer. Often the contributors miss it and we need to hear what was really going on. Thanks
Tom48
In Sunny So Cal /w
Now in 2005 Holiday Rambler Ambassador DP and The Hot Air Balloon RESTLESS
NO MORE Tricked out
2017 Sandstorm 250 T.H.
Tom48 is offline   Reply With Quote
hot water, water
