Old 02-01-2018, 08:38 PM   #1
Outside TV
I have a 2017 Coachman Mirada Select 36BHF and would like to change the outside TV. Has anyone tried this and if so how difficult of a job was it?
surfnkona2 is offline   Reply With Quote
Old 02-02-2018, 11:49 AM   #2
I can't help you but I'm looking at a new pursuit...are the tvs no good. Just curious why your changing? ?
52chevy is offline   Reply With Quote
Old 02-02-2018, 01:10 PM   #3
Want to install a smart TV, also want to hook up a Amazon Fire Stick. So I am going to mount a swing are and put a new TV on it.
Old 02-03-2018, 07:19 PM   #4
World Wide Wanderer
wahoonc's Avatar
I would guess it is mounted similarly to mine. Mine is hard mounted to a piece of plywood that is then screwed to the wall framing. Take the screws holding the plywood in place out then catch the TV before it hits the ground. Remove the screws that hold it on, then rebuild to suit. Just check your clearances for the swing mount.
Aaron
Aaron & Rhonda
wahoonc & Airangel60
2016 Coachmen Concord 300DS
2015 Fusion Hybrid following along
wahoonc is offline   Reply With Quote
Old 03-28-2018, 08:14 PM   #5
I pulled my tv off and attached a swivel/telescoping mount on the original Furion TV... It wasn't too hard to remove, just a few wood screws here and there
robjordan406 is offline   Reply With Quote
Old 04-07-2018, 05:10 AM   #6
On our 2016 Pursuit, I replaced the inside TV's which are Seiki with Samsung. Seiki is a cheap tv and did not care for the lack of brilliance of the picture. I did not mess with the outside tv, 1. don't know how to get it out, 2. We don't use it. I also installed Samsung sound bars because of the loudness of the A/C's makes it hard to hear the TVs.
2016 Pursuit 33BH,
2012 Jeep Wrangler,
Sondors & Bolton E-Bikes
Blue OX
cberlanga is offline   Reply With Quote
Old 04-08-2018, 08:31 PM   #7
Sound Bar
Do you have any pictures of the sound bars you installed?
Old 04-08-2018, 08:32 PM   #8
Any pictures of you sound bars you installed?
