Old 09-21-2020, 07:22 PM   #1
Overhead bunk will not operate
Our overhead bunk in our 2018 Coachman Pursuit 32sb would not work this past weekend. Read the manual, tried under “shore” power and generator power, nothing. The blinking lights one red and one green kept alternating back and forth. Pulled the control panel and pressed the master reset and still same results. Any one out there have similar issues? Where is/are the motor/motors located and how do you access them?? Thanks in advance Mike
english cream retrievers is offline   Reply With Quote
Old 09-22-2020, 10:37 AM   #2
Witch Doctor's Avatar
Call Coachmen that is your best bet, there very good with walking you through things to check, sounds like an electrical problem maybe a pinched wire. I’m sure they can help you out. I would take a guess it access your motors you will have to remove the trim.
Coachmen M/H
Concord
2018 / 300 DSC
bunk
