Originally Posted by gerryb723
I have a 2018 Prism 2200. Best mpg is 14 so far with 10k miles using the chassis auto mpg calculator. How does that compare to others? Will the mpg improve with more miles on the engine?
We typically get 14+ mpg when towing the Sonic and 16ish if not towing - as long as we don't have a headwind. The worst we have done is 12.8. The best 17.2. I usually set cruise on 60-62. I am not aware of any auto mpg calculator.
I suspect the G model that doesn't have the front overhang is a little more aerodynamic and also weighs a bit less.
The last time I weighed I was 1000lbs (14250 with car/dolly) under GCWR and about 50 lbs (10980) under GVWR.
Mike and JoAnne
Montana Summer / Arizona Winter
2016 Prism 24G /2002 HitchHiker 38LKTG
ACME EZTowing a 2015 Chevy Sonic RS Hatchback
