After spending 5 days out in the forest (family of 5), running the furnace at night, fridge and water heater, we only burned a 1/4 tank of propane. So I think it's time to step up and get a propane grill for the RV (I typically bring my large Weber charcoal grill or sometimes just use the campground facilities.)
After doing a little homework the camco 3 port seems to be what I need. Not sure what model though and debating installing upstream or downstream from coach's regulator. It's my understanding if installed before the regulator then any/all my accessories will need their own regulators (as for accessories - I have none at the moment.... just trying to think ahead and only do it once). If installed downstream, then it's already regulated and I can't use accessories that have regulators too (No double regulating the propane right?)
Guess it's neither here nor there, just want some friendly advise from the "been there done that" &/or "I wish I woulda" camps. I guess the only reason this question came up for me was the RV grill I was looking into did not have a regulator so it could be used with coaches that had a built in low pressure quick connection (camco Olympian 5500)
Not sure about other accessories I might be interested in??? Like lanterns or heaters? I do use a campchef two burner camp stove with a 5 gallon tank I bring with it. (I want to eliminate bringing that tank too).
So I guess I'd go with the 59103 (3-port tee) installed before the coach's regulator. Run a hose to a propane splitter to connect my regulated two burner cooktop and shop for a nice regulated RV/portable/tabletop grill??
