Old 03-26-2020, 10:44 PM   #1
sa1jzm's Avatar
Replaced Dometic 301 Toliet
My 6 month old Coachmen bathroom started to smell like a portapotty. Read online that there were potential issues with liquid seaping into an internal area on some models, So, I bought a porcelain upgraded Dometic 311 and installed it tonight. Took the ďoldĒ toilet out and sure enough it was filled with urine! Ugh. Iím calling Dometic tomorrow and see if I can get some relief (New toilet only cost $160, but!)
sa1jzm is offline   Reply With Quote
Old 03-27-2020, 10:26 AM   #2
Nice...
We're looking to replace ours with the 320 Low Profile (Short Legs! )...
Any gotchas with the fit or placement?
Thanks!
Nate Ravid
2018 Freelander 27QB
nravid is offline   Reply With Quote
Old 03-27-2020, 12:53 PM   #3
We tried to replace ours....but the back part didn't fit in the hole that Coachmen uses to bring the water in.
I'll have to look at your model, I can't remember which one I tried, and see if it fits in our 2018.
Jim
2018 Coachmen Freelander 27QB
CC38EL is online now   Reply With Quote
Old 03-27-2020, 01:06 PM   #4
Jim,
I have the same Rig as you, so hopefully, if you have any pics or advice, I'd be happy to see!
Thanks!
Nate Ravid
Old 03-27-2020, 05:47 PM   #5
sa1jzm's Avatar
Hereís the pics from my install of the 311Click image for larger version
ID:	225860Click image for larger version
ID:	225862Click image for larger version
Old 03-27-2020, 08:48 PM   #6
Looking at the pics and the 311 online, I see where my difficulty was. I tried to put in an Aqua Magic and the hose access didn't quite line up.
From these pics it looks like if you take a Dometic out, you have to put a Dometic back in.
Thank you for the pics. When I get the coach back, a new Dometic is going in. Hate that plastic bowl!
Jim
Old 03-28-2020, 03:40 AM   #7
Thanks for the pics. I am hoping that the 320 will be a straight-forward rip-and-replace installation. I'll post any updates!
Nate Ravid
Old 03-28-2020, 01:02 PM   #8
sa1jzm's Avatar
It was really easy... hardest part was lining up the bottom bolts!
Old 03-28-2020, 03:43 PM   #9
You can see a spec sheet for all of the dometic toilets on their web site. All the mounting dimensions are shown so you can check clearances before ordering. I replaced the 300 with a 320 with spray hose. Big improvement.
markb422 is offline   Reply With Quote
Old 03-28-2020, 03:58 PM   #10
nomad297's Avatar
If you have 2-1/2” of space between the back of a 300 and the wall, a 320 will fit.
If you currently have a 301, all you need is 2-1/4”.
Bruce
Old 03-28-2020, 04:33 PM   #11
AudiDudi's Avatar
I just replaced an Aqua Magic IV with a Dometic 310. I had to buy a new hose to go from teh floor to the back of the toilet. The 310 also sits out an inch further from the wall - the wife says it will be easier to clean behind.
Mike and JoAnne
Montana Summer / Arizona Winter
2016 Prism 24G /2002 HitchHiker 38LKTG
ACME EZTowing a 2015 Chevy Sonic RS Hatchback
AudiDudi is offline   Reply With Quote
dometic
