Originally Posted by jjd74
Hello all. I've a problem with the passenger side camera - somehow it took on water. I've removed the three screws holding it against the coach but it still appears attached and unmovable. Has anyone taken one of these off? I need to get the moisture and water out. Thanks.
I have the same problem. Try a hair drier first to get rid of the water before taking it off. If it comes back ( which it will) , it has to come off, come apart and be resealed. These are supposed to be water tight but some do eventually leak. Yours is probably just stuck to the side of the coach with sealant or putty tape. Heat it up a bit with the hair drier and try pulling or pry with a plastic putty knife. Hopefully they left enough slack in the cable.
Disassemble and reseal the lens cover and bottom cover. If the lens cover isn't loose or doesn't fall out leave it alone and just reseal it carefully from the outside. I used aquarium sealer, so far so good. Yes, it's silicon, the worst thing you can use on an RV but this is a camera we're sealing not a roof, door or window. Reinstall with putty tape and hopefully it will be dry for a long time.
