Old 03-23-2019, 06:44 PM   #1
Sink draining issues
I just finished dewinterizing my coach and now my sink and shower are not draining. I filled my fresh water tank and emptied the antifreeze. I then dumped both my black and gray tanks and then pumped a bleach solution into the fresh water tank. I then opened all my faucets until I smelled the bleach from each one. Now my sink and shower will not drain. Any suggestions?
ddamron is offline   Reply With Quote
Old 03-23-2019, 06:50 PM   #2
markb5900's Avatar
Look for a wasps nests in top blocking your air flow
Mark B
2015 32 Foot Rockwood 8289WS 5th Wheel
2017 GMC 3/4 Ton TV
markb5900 is offline   Reply With Quote
Old 03-23-2019, 06:56 PM   #3
replace the air admittance valve under the sink. It is attached to the drain.
Old 03-23-2019, 09:20 PM   #4
A while back someone here taught us that sink and shower may not drain if your camper isnt level.
Skip12 is online now   Reply With Quote
Old 03-23-2019, 09:30 PM   #5
Jayhawker
Jayhawker's Avatar
I would start by first checking your plumbing vent on the roof and air admittance valve under the sink.
Jayhawker is offline   Reply With Quote
Old 03-23-2019, 09:42 PM   #6
The only time I had that problem in a prior unit, I was advised to get a wire and push it through the grey valve. It worked, but you need a 5 gal bucket. MHO
2017 Leprechaun 311 FS
Jeep Patriot and Cherokee as toad.
Enjoying retirement.
jonwisconsin is offline   Reply With Quote
Old 03-23-2019, 09:48 PM   #7
Mr. Dan's Avatar
I believe the OP said the sink and shower are not draining... didnít say waste tanks werenít draining.
SEARCH is your friend!
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 = 111/'19 = 86/'20 = 26; booked = 42
drain, sink
