Old 03-08-2020, 10:33 AM   #1
Slide stuck out 2018 Coachmen Pursuit 32wc
I have a 2018 Coachmen Pursuit 32wc and the slide is stuck out. How can I Manually retract the slide. It is the large slide on the drivers side.
thanks
Notime2go is offline   Reply With Quote
Old 03-11-2020, 03:19 PM   #2
Commercial Member
ES_FR's Avatar
Notime2go,
We would be happy to assist you with your slide. Please contact Tim Buss in our Customer service department through the following personalized and direct link: https://www.coachmenrv.com/DirectSer...95403044933412.
This direct link is provided for your convenience in order that we may resolve your concerns as quickly as possible. We will strive to respond to you within 24 hours of receiving your correspondence.
Respectfully,
Forest River
ES_FR is offline   Reply With Quote
Old 03-15-2020, 12:52 PM   #3
Lippert slide component #366701 does it have a reset switch. I can not located it.
Any one in the Easton PA area that can recommended a mobile service? I have spoke with 3 and they do not seam to be interested.
thanks
Name:	lippert slide component.jpg
Old 03-15-2020, 01:08 PM   #4
thanks
There is a small grey button next to that red light . press it 6 times holding it in on the last push untill the light flashes then go in and see if it operates
MR.M is offline   Reply With Quote
Old 03-15-2020, 02:13 PM   #5
I cant locate any button next the light. thanks anyway.
ID:	225217   Click image for larger version
ID:	225218   Click image for larger version
Old 03-15-2020, 03:10 PM   #6
It's the small grey one right next to the light in the picture, use a pen to push it
coachmen, slide
