Old 06-24-2019, 06:32 PM   #1
Staining from RV windshield cover
Our windshield cover on a Freelander 20cb micro is showing some staining where the magnets hold the cover. Has anybody experienced this and do you have a remedy?
Maurice1 is offline   Reply With Quote
Old 06-24-2019, 08:39 PM   #2
Cover
Staining is showing on the paint of the cab
Old 06-26-2019, 09:59 AM   #3
Hi Maurice,
Are they rust stains from the ferrous magnets? If so, can the paint be more safely isolated by placing a plastic sandwich bag, or other small, thin piece of plastic wrap, between the cover and paint?
If it were to be rust, a dab of vinegar water might safely remove the stain.
Thanks,
Wes
2019 Leprechaun 311FS
Wes, Linda & Quincy (std. Brown Poodle)
Wes Tausend is offline   Reply With Quote
Old 06-26-2019, 10:02 AM   #4
Originally Posted by Wes Tausend View Post
Hi Maurice,
If it were to be rust, a dab of vinegar water might safely remove it.
Thanks,
Wes
The magnets are contained inside the cover fabric . I will try a little vinegar to test.
Old 07-23-2019, 09:43 PM   #5
Once you have it cleaned make sure you wax it good. Those covers hold moisture behind them just like the old bra covers for a car. If you notice no one uses them anymore because they did more damage then good. If you leave yours on for long periods at a time you should wash and wax the areas it covers more often.
nvs4602 is offline   Reply With Quote
cover
