Old 09-16-2019, 09:38 AM   #1
meg
Tow vehicle behind a Mirada
Trying to decide if we want to pull a Jeep Wrangler Rubicon 2 door or a Jeep Wrangler Unlimited 4 door. Don't know if our 2011 Mirada will be able to handle either one. We want to flat tow.
meg is offline   Reply With Quote
Old 09-16-2019, 10:29 AM   #2
World Wide Wanderer
wahoonc's Avatar
For starters, please list the year and the specific unit you have.
The tow ratings should be in your owner's manual or documented somewhere.
Most motorhomes have tow ratings ranging from 2,000#-5,000#. Some of the larger DPs and Super C have much more.
Aaron
Aaron & Rhonda
wahoonc & Airangel60
2016 Coachmen Concord 300DS
2015 Fusion Hybrid following along
wahoonc is offline   Reply With Quote
Old 09-16-2019, 11:20 AM   #3
If you have the right hitch, you should be ok. If you have a 5,000#, you might be pushing it.
2017 Leprechaun 311 FS
Jeep Patriot and Cherokee as toad.
Enjoying retirement.
jonwisconsin is offline   Reply With Quote
Old 09-16-2019, 11:21 AM   #4
chroniekon's Avatar
I googled 2011 Mirada and the towing capacity for the 34BH model is 4000 lbs.
2017 Isata 3 24FW
2004 Jeep Wrangler
chroniekon is offline   Reply With Quote
Old 09-16-2019, 12:52 PM   #5
Dahagen
I have just about the same Mirada and tow a Suzuki Grand Vitara just fine. Don't even know it's there except on the hills. Specs say 4000 pounds, so check the weight of the Jeep products.
dahagen is offline   Reply With Quote
Old 09-16-2019, 10:42 PM   #6
BigHomey's Avatar
The Mirada has a 22K pound GVW (coach alone) and 26K pound GCVW (coach and toad). So the Mirada is limited to 4,000 pounds IF you are at GVW on the coach. I had mine weighed when we were loaded for travel - all supplies, tools, full of fuel, 1/3 fresh water, empty black and gray tanks, 3 people and a dog. I thought I would be close, but I am way under the GVW for the coach - 19,880 pounds. My Cherokee toad full of fuel weighed 4,260 pounds, so when added to the coach still only gives me 24,140. Still way under the 26K total.
If I decide to go to a heavier toad, I am still limited by the 5K receiver.
You best bet is to get weighed and hope that the Wranglers are under 5K pounds.
AL
2016 Coachmen Mirada 35KB
2016 Jeep Cherokee 75th Ann. Ed.
2007 Corvette Convertible
1997 F-350 CC PSD
BigHomey is offline   Reply With Quote
Old 09-19-2019, 11:08 PM   #7
I think you need to look elsewhere.
This is the information I got about weight of a Wrangler
3,970 to 4,439 lbs
tow vehicle
