Old 08-07-2021, 05:20 AM   #1
TPMS Dually Rear Tires
Good morning, if you only had 2 monitoring caps for the rear wheels which tires are most important, inside or outside? Thank you
SFBeck is offline   Reply With Quote
Old 08-07-2021, 06:19 AM   #2
Caliwish's Avatar
I notice that the outside ones increase in pressure faster as you drive longer.
Caliwish
Caliwish
2012 Coachmen Freelander 32BH
Caliwish is offline   Reply With Quote
Old 08-07-2021, 12:58 PM   #3
The outside ones increase the pressure faster because sometimes the sun hits them. However, I would use them in the inside as they take more work in my opinion.
2017 Leprechaun 311 FS
Jeep Patriot and Cherokee as toad.
Enjoying retirement.
jonwisconsin is offline   Reply With Quote
Old 11-15-2021, 07:55 AM   #4
Chief tinkerer
Gidyupgo's Avatar
OK, I'll play;
Put them on the ones that will get cut from road debris or pick up a nail, heh, heh. Sorry, couldn't resist.
At 40k miles, I had an inside dual with a slow leak picked up by TPMS, which prompted me to stop by a tire store to find the nail. What they found was a knot on the inside sidewall that they said was typical of impact damage from a curb or pot-hole. I would never have seen it, being on the inside, and it would have eventually failed, bringing all the danger and drama that doing a tire change on the freeway shoulder brings.
Also, pressure is a little more difficult to check on the inside tire, so if I HAD to choose, it would be the inside tires, while waiting for the other two sensors to arrive.
Gary
2017 SunSeeker 3010DS
Gidyupgo is offline   Reply With Quote
Old 11-15-2021, 12:44 PM   #5
A TPMS is an early warning device. So is the human eye. If I had a truck/coach with dual wheels I would put the "early warning device" on the wheel that is hardest to see or "kick".
It would be best to have sensors on ALL wheels.
2023 f-150 SCREW XLT 3.5 Ecoboost (The result of a $68,000 oil change)
TitanMike is offline   Reply With Quote
Old 11-15-2021, 12:53 PM   #6
I agree with @TitanMike. TPMS all around.
Additional sensors shouldn't be that expensive. I pay $50 per valve stem for our TPMS (PressurePro).
2019 Cedar Creek Silverback 37MBH
TV: 2017 Ford F350 CC DRW King Ranch
jd4010 is offline   Reply With Quote
tire, tires, tpms
