Old 03-30-2019, 02:03 AM   #1
Water pump location
Anyone know where the water pump is located in my 2017 Leprechaun 210 RS?
Itís so noisy it sounds like itís located in the entire coach.
Wvfullmoon is offline   Reply With Quote
Old 03-30-2019, 02:14 AM   #2
CincyGus's Avatar
Usually near the fresh water tank or the bathroom under the sink cabinet. Look for a flat panel with screws in it. They are often covered with a removable panel so you can get in to winterize.
Hint for the noise. When you find it, remove the mounting screws, put some little rubber squares under the mounting feet and reinstall the screws. Will remove the vibration from the motor and help reduce the sounds like it's everywhere feeling.
2020 Chevrolet 2500 LTZ, 2019 Forest River Wolfpack 23Pack15, 2014 EZGO Golf Cart.
CincyGus is offline   Reply With Quote
Old 03-30-2019, 07:42 AM   #3
open all cab door at floor level, pull open drawers, open storage doors outside. Open a faucet and turn on the pump walk around the rig and follow the noise. It's hidden behind some panel. Why, Nobody knows. Every coach is different. Where they put them depends on what day it is. Even within the same model and floor plan.
Old 04-22-2019, 11:51 AM   #4
Try under the shower.
Accessible through the basement. Good luck!
RVPhD is offline   Reply With Quote
Old 04-22-2019, 12:22 PM   #5
Key... look for the wall panel that is held in place by screws Vs nail/tacks and trimmed. It will be behind it. Mine is inside of pass thruvery close to fresh water tank.
gbaldwin is offline   Reply With Quote
Old 05-02-2019, 04:57 PM   #6
Water pump location
Mine is located under outside kitchen sink with an access panel.
Also has a macerator for outside sink.
2017 Pursuit 30FW
Bytesponge is online now   Reply With Quote
Old 05-02-2019, 05:06 PM   #7
Mr. Dan's Avatar
I recommend we wait until the OP returns to the site and replies to his thread.
Re: OP === Last Activity: 04-11-2019 02:58 AM
SEARCH is your friend!
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 = 111/'19 = 86/'20 = 26; booked = 42
cat, location, pump, water, water pump
