Old 10-29-2019, 10:45 AM   #1
Water pump location 2019 Coachman Leprechaun 260ds?
Can anyone tell me where the water pump is located on a 2019 Coachman Leprechaun 260ds? Iíve looked under bathroom sink, kitchen sink, stove/oven. What am I missing? I cannot turn it on to listen as I have winterized lines but I need to check for water in line at pump.
cyberteach is offline   Reply With Quote
Old 10-29-2019, 10:58 AM   #2
SeaDog's Avatar
With the pump off realize a little of the pressure on the system and turn the pump on search out the sound while it builds pressure again. Antifreeze is cheap just add back what was lost. If you winterized using the pump it should have on water in it.
Retired Navy
2016 Flagstaff 26 FKWS
Old 10-30-2019, 07:44 AM   #3
If you open your rear driver side storage area, the wall towards the front of coach can be removed, the pump is right there......Bruce
Bruce and Sandy
2007 Scepter 42PDQ--Sold
2018 Coachmen Leprechaun 26DS Chevy
waco kid is offline   Reply With Quote
cat, location, pump, water, water pump
