Water pump location 2019 Coachmen Leprechaun 260ds?
Can anyone tell me where the water pump is located on a 2019 Coachman Leprechaun 260ds? I’ve looked under bathroom sink, kitchen sink, stove/oven. What am I missing? I cannot turn it on to listen as I have winterized lines but I need to check for water in line at pump.
With the pump off realize a little of the pressure on the system and turn the pump on search out the sound while it builds pressure again. Antifreeze is cheap just add back what was lost. If you winterized using the pump it should have on water in it.
Retired Navy
2016 Flagstaff 26 FKWS
