Old 08-26-2019, 03:20 PM   #1
Water Pump Wont Turn Off?
Anybody else had this issue? We have a lighted switch for the water pump - turned it on no problem but when we turn the switch off it stays lit and pump still has power?
Switch issue? Pump issue?
Any help appreciated.
RVJeeper18 is offline   Reply With Quote
Old 08-26-2019, 03:26 PM   #2
bubbles's Avatar
Light in switch is just to show switch position and not controlled by pump. I vote switch.
Old 08-26-2019, 03:31 PM   #3
Sounds like a broken switch to me. If it wasn't turning off with the switch on I would think it was a leak. That happened to me when I left the gasket out of my water filter housing.
2016 Sunseeker 2700DS
2010 Jeep Liberty Toad
tlf65 is offline   Reply With Quote
Old 08-28-2019, 11:55 AM   #4
Without knowing what model, year, etc., of your unit is difficult to help you. What I know is that some units like mine has two switches. One inside in the normal panel and another outside where the hoses connect. When the outside is on, it overrides the inside one. I need to make sure that the outside is off in order to have control from the inside one. However, as I said, without having more information about your unit this might not apply to yours.
2017 Leprechaun 311 FS
Jeep Patriot and Cherokee as toad.
Enjoying retirement.
jonwisconsin is offline   Reply With Quote
Old 08-31-2019, 03:44 PM   #5
World Wide Wanderer
wahoonc's Avatar
I agree with jonwisconsin. I bet the outside switch is on. I have done that a couple of times with mine.
Aaron
Aaron & Rhonda
wahoonc & Airangel60
2016 Coachmen Concord 300DS
2015 Fusion Hybrid following along
wahoonc is offline   Reply With Quote
pump, water, water pump
