Old 08-14-2019, 08:22 AM   #1
Wheel lug sizes along with hubcap lugs 20cb Ford Transit 350hd
I had the experience of looking for a replacement lug after getting a tire checked.It probably fell off since I found quite a few loose.Thinking it was the wheel lug I was not able to get the correct sized lugs from Ford. I had no idea the wheel lugs were actually under the hubcaps which had their own huge sized lugs with extensions.Turns out they were Dicor brand. Once again getting info from Forest River this was never answered.Just thought I would share this as I continue to find a parts list.
NB2A is offline   Reply With Quote
Old 08-14-2019, 08:37 AM   #2
clr
Yep the real lug nuts are always under the hub cap. I would just remove the hub cap and remove an existing lug nut and take that nut to an auto parts store, they will be able to get you the right replacement lug nut. Most lug nuts come in one of three bolt sizes, 1/2, 9/16 and 5/8 of an inch I think. There are also several configurations of each size but taking the lug nut in they will be able to match it up.
Chuck & Sandra
Engineer/Teacher
2010 F350 CC 6.4
2015 Prime Time Sanibel 3601
clr is offline   Reply With Quote
Old 08-17-2019, 11:02 AM   #3
Wheel lug sizes
Scroll down to ISO WHEEL SIMULATOR NUTS I had the same predicament and hopefully the answers will be there for you.
Maurice1 is offline   Reply With Quote
ford, wheel
