Originally Posted by shortkid
We have a 37tz, 2015 also. The fresh water tank is under the big curb side slide. With the slide out,there is a removable panel allowing access to it. The black tank goes from there to the other side over the dump valve. The grey tank is over the wet bay under the bath area. The panel in the wet bay hides all of this. Hope this helps. We don’t get out in the cold weather,but I think some heat in the wet bay would keep you safe. There isn’t much space in there though. Good luck.
I have a ‘13 TZ. To keep wet bay warm and provide some heat to tank I had a 117 volt bilge heater installed in the wet bay. It has thermostat controlled on/off point. When camping in cold weather I just plug it in and it does the rest. To buy, have it installed and a 117v line run to wet bay ran me $405. If you are handy and electrically talented you can trim the cost significantly.
1nshort
2013 Encounter 37TZ, Chalet Pkg, Escape Hybrid Toad,
Denis & Gail & Dixie the Blue Merle Sheltie
