Originally Posted by jonwisconsin
This is a like a chatter noise on the window, like the window frame is not tight enough. ????
Possible. Can you test drive a different unit and see if it has the same noise? That was one of the things we did when we bought ours was to test drive it before signing on the dotted line. I consider that part of my PDI, along with making sure everything works.
If you drive a second unit and it makes the same noise you know it may be a design issue, if it doesn't make the noise you know it is specific to that unit. Wind noise can be hard to track down and repair. If you can't fix it, you will be stuck with it as long as you own the unit.
Aaron
