Old 02-22-2021, 01:02 PM   #1
12v Overhead Light Replacement source?
One of my 12v 9" long ceiling lights went out and wanted to check if anybody has replaced them before and where to source them? Thanks!
CruisinCarlz is offline   Reply With Quote
Old 02-22-2021, 01:21 PM   #2
rk06382's Avatar
I replaced my ceiling lights with two-mode LED lights after the original LEDs failed. see: 07-25-2019 post below:
Originally Posted by rk06382 View Post
I replaced my original ceiling lights with two-mode lights. I bought the two mode LED lamps from Amazon:
AutoEC LED Dome Light, 2 Color Mode 12V LED RV Ceiling Dome Light Fixture, Interior Replacement Light for RV, Trailer, Camper, Motorhome, Boat
2 Mode Fashionable Design --- The Dome Light with on-off-on switch, can change the color from pure white to warm white, give you different feel. Warm white light output provides a cozy illuminated environment just like home. I have six installed & control the color mode with a wall switch. It only draws 5 Watts and provides total 1000 lumens of brightness.
My FR3 in White Light.
My FR3 in Warm Light
I have six installed & plan to replace more.
Robert
2018 FR3 28DS | Boondock 99% of the time
Samlex EVO-3012 Inverter/Charger | 600ah Battle Born LiFePO4 | Victron BMV-712 & MPPT 100/50 | 800W Renogy Solar | Fan-Tastic Fans | Blue Ox TruCenter | SnapPads | SumoSprings | Koni Shocks | RVLock
Solar Power & Battle Born batteries
rk06382 is offline   Reply With Quote
Old 03-01-2021, 11:37 AM   #3
I bought some 12V Led light strips and soldered in to the red/black wire on every single LED overhead in our 32DS. The originals were junk, were flashing intermittently, etc. So I just replaced them all and stuck these up there. Took a few hours one afternoon but worth doing them all at once!
Griswards is offline   Reply With Quote
Old 03-01-2021, 08:00 PM   #4
Where they hard to replace? Never have I changed out anything electrical.
stlcardbesties is offline   Reply With Quote
Old 03-02-2021, 02:09 PM   #5
rk06382's Avatar
Just splice the wires. It comes with wire nuts. see below:
The biggest issue is the (-) wire on the FR3 is WHITE & on the new light (-) wire is BLACK . The new light is larger to cover your old screw holes.
Robert
Old 03-02-2021, 02:14 PM   #6
Kanadian Kamper
kenandterry's Avatar
Just remember......LED lights are polarity sensitive. Nothing scary, just if you wire them backwards or opposite, they don’t work at all. Keep the coloured wires matched and you should be okay, but if they don’t work, just reverse the wires to be sure, and test them again.
Ken and Terry
kenandterry is online now   Reply With Quote
Old 03-03-2021, 06:08 PM   #7
12v replacement
Here is the exact replacement, I have replaced 6 or 7 of them.
KICORED Ceiling Lights with ON/Off Switch 12v Led Light Interior Fixtures for RV Lights,Trailer Lights,Camper Lights and Boat Lights Warm White 3400K (Pack of 3)
https://www.amazon.com/KICORED-Ceili...4812751&sr=8-1
Meader777 is offline   Reply With Quote
light, replacement
