Old 10-09-2024, 10:48 AM   #1
34ds Vehicle Weight
Doing a survey for folks that have a FR3 34ds. What is your UVW (unloaded vehicle weight)? And if you know it, your total cargo carrying capacity?
I have a 34DS 2021 with the V8 but I am missing the sticker that has the UVM/CCC information on it. I realize that they are all slightly different, hence that is why I am surveying this group.
Thanks!
TJ
tjh31971 is offline   Reply With Quote
Old 10-09-2024, 12:10 PM   #2
RVwino's Avatar
Here’s my yellow sticker.
Cliff Smith
Jackson, CA
2021 FR3 34DS (V8)
2011 Honda CRV toad
RVwino is offline   Reply With Quote
Old 10-10-2024, 12:43 PM   #3
Commercial Member
If you can PM me your VIN I should be able to help get this info for you here at the factory. Thanks!
Don Roeder
DRFR3 is offline   Reply With Quote
Old 10-10-2024, 07:38 PM   #4
NXR
NXR's Avatar
For a motorhome it's called OCCC, Occupant and Cargo Carrying Capacity. The US sticker is supposed to be very close to the entry door. Ours is on the door frame.
The US sticker is created with the fresh tank empty but shows the weight of the water for reference.
The Canadian sticker is created with the fresh tank full and will display in kilograms and also have French wording. This one is usually on the wall behind the driver.
Note that the OCCC figure, while is does include all factory-installed options, is just the starting point. If you bought used then anything the previous owner(s) added will subtract from the factory OCCC but you have no idea how much that stuff weighed. Your best bet is to get the motorhome weighed at a CAT Scale while it's fully loaded up for a trip.
Ray
2020 Georgetown GT5 34H5
NXR is online now   Reply With Quote
Old 10-19-2024, 04:47 PM   #5
I found the info in my RV. Thanks everyone... for giving me info in the meantime
2139 lbs is my occc.
weight
