Old 02-08-2019, 03:28 PM   #41
Originally Posted by Combatcoal View Post
Here it is installed. I put up the trim first then installed the louver/vent next. I decided to screw the system into the metal of the air conditioner rather than into the roof. Donít overt tighten or else the louver and filter wonít slide easily. You can see the edge of the old frame where I need to clean it up. I used a better dense foam insulation rather than what they provided. The sticky tape they provide is so so.
Attachment 196385
Did they give a part number for the new trim piece ? If so, can you post it just in case they don't send it any time soon, I can call and ask about it with the part number.
Thanks,
Bob
Kentucky Bob is offline   Reply With Quote
Old 02-08-2019, 06:13 PM   #42
I never checked for the part number, I tossed the box and paperwork at my work. Sorry.
Combatcoal is offline   Reply With Quote
Old 02-11-2019, 09:51 AM   #43
edm
AC Grill Trim
FYI, i just got in contact with Dometic and they said my trim peace would be shipped 2/14/2019. Part number is 3317203.000
Hope this helps.
edm is offline   Reply With Quote
Old 02-26-2019, 10:10 AM   #44
Originally Posted by RDANGER View Post
Anyone here have issues with A/C leaking in the MH....had it checked out 3 weeks ago, and they said that they ran it all day and it didn't leak.....I run it for 4 hours and I have a flood....how do you add a video?
Rita
My dealer Giant Recreation World in Ormond Beach FL found that there was a recall on the AC units on our 2018 FR3 30DS came with and replaced ours.....no more leaks.
BAJAG is offline   Reply With Quote
Old 03-02-2019, 08:07 AM   #45
Install instructions?
Thanks for all the info in this thread. I got in contact with Dometic this week. The new cover arrived yesterday and the trim piece is to arrive today. I did not see any instructions. Is it pretty intuitive on how the metal plate is installed once I open it up? I hope to do this over the weekend. Thanks. I will report back my experiences.
yensidcamper is offline   Reply With Quote
Old 03-02-2019, 08:57 AM   #46
Usually Confused Member
emm-dee's Avatar
Refer back to post #17 in this thread. Much better instructions than youíll get with the kit.
2018 Forester 3051S (aka Clyde)
2015 Wrangler Toad (aka Bonnie)
At some point during every day you suddenly realize nothing else productive is going to happen the rest of that day. For me, it usually occurs around 9 am.
Old 03-02-2019, 09:20 AM   #47
edm
The instructions will be in with the trim peace. At least there were instructions with mine.
Old 03-02-2019, 07:36 PM   #48
Thanks guys. I didn't go back and read the earlier posts. Post 17 is great. I did get the trim piece today and it had instructions as well. I hope to get this installed tomorrow. Thanks again for the responses.
Old 03-10-2019, 10:25 PM   #49
Installed today
I got to install the cover and trim piece today. The directions on post #17 were spot on! Thank you! I am attaching the directions that came with the new pieces. I found them to be difficult to read. The pictures are very poorly done IMO.
The one thing that shocked me is how they only use aluminum tape to cover the "ducts" in the Styrofoam in the roof. This leaves very little separating the warm return air and the cold supply air. The new system is much better than the old one but wow they should have closed that off better.
Thanks again to all who have posted on this thread.
Old 04-07-2019, 01:44 AM   #50
Dometic vs Atwood
Thank you for the info in this thread. I have a 2017 FR3 29DS built in Jun of 2016. It has Atwood AC's according to my paperwork that I got from the dealer. It has a 13500 AC only in the Bedroom and a 15000 BTU heat pump in the living area. I've read Atwood and Dometic had some sort of merger in 2017. My question is, can I expect to get customer service from Dometic as described in this thread? I got water running out of my fascia cover today for the first time. We have used the RV sparingly in the one year since we purchased it. Today was Saturday and I will try to contact them on Moday. Since the ceiling cover looks exactly the same as the one shown in the photos here I was wondering if anyone else in this thread had an Atwood AC.
Thank you
Ben
benj is offline   Reply With Quote
Old 04-07-2019, 07:22 AM   #51
emm-dee's Avatar
Thank you
Ben
Yes, Dometic provides full support for the Atwood. Give them a call and describe the problem and ask for Service bulletin 3315930.010
Old 04-08-2019, 07:02 PM   #52
I donít have mine fixed yet but Dometic does have a fix for the leaking ac. I will post with pictures once it is done. Dealer ordered parts and I havenít taken the MH back to them yet.
Master gunner is offline   Reply With Quote
Old 04-08-2019, 07:30 PM   #53
emm-dee's Avatar
Why get a dealer involved. Theyíll probably keep your unit for a couple of weeks to do a job that takes maybe 30 minutes. Order the parts from Dometic (theyíre free), look at post #17 in this thread and do it yourself.
Old 04-08-2019, 11:36 PM   #54
Dometic vs Atwood
/Thanks again emm- dee and all. I called Dometic today and talked to customer service . The woman I talked to was very pleasant and was familiar with the problem and said she would send me two sets of new vents and trim kits possibly leaving today by UPS.
Ben
2019 FR3 29DS, CHF, Koni shocks, Rear Sumo Springs,
Rear Trac Bar, Safe T Plus. Crew DW, 2 Std Poos, Moxie and Lucy.
Old 04-09-2019, 05:32 PM   #55
I called today and my parts are on the way. They were very helpful. My be a quick fix so thanks for the info.
Black Knight is offline   Reply With Quote
Old 04-11-2019, 02:28 PM   #56
Send a message via AIM to DannyFaye Send a message via MSN to DannyFaye
trim for ac repacement
thank you for the info....could you please send me an email address for Dometic??
Rita
has anyone received the trim for the replacement part for air conditioner yet
DannyFaye is offline   Reply With Quote
Old 04-11-2019, 03:48 PM   #57
Just got mine today. Go to their web site as it has the phone numbers and email addresses.
Old 04-11-2019, 03:53 PM   #58
The OP hasn't responded back since September 4th 2018. Don't think they're coming back.
TheWolfPaq82 is offline   Reply With Quote
Old 04-13-2019, 06:07 PM   #59
Put my new new mod for the air/heat in today. Thanks to all for your help.
Old 04-16-2019, 05:53 PM   #60
Capt6pak's Avatar
mine did the same thing, its a issue with the installation. they had to take mine off and cut the foam insulation so it would drain. the foam fell or was to tight. once they did that it cleared up.
later the dealer said the also ordered and installed a new updated piece for it but it looks just like the one that was on it
2018 FR3 30DS
1997 and 2018 Wrangler
Capt6pak is offline   Reply With Quote
fr3, leak
