my unit looks a little different but the panels just pop out with plastic tabs. if you need to take the whole cover off mine has screws hidden under those panels.
Insert a flat screwdriver into those 1/2 slits and press the tip toward the larger side of the vent. There is a plastic tab that holds it in place, much like the battery compartment on your tv remote.
