Old 03-14-2020, 05:32 PM   #1
Added external water inlet on FR3
Thought I would share my latest project to my 2014, FR3 25DS. I wanted to add an external water fill for city water and tank water. The first picture shows the location where I put the city water connect inlet. The second picture shows city water coming in from the left, going through the water filter, out of filter over to a pressure regulator (50-55psi) on the right, then down to the main shut off valve. After the shut off valve, I added an in-line water pressure gage as a visual safety precaution so I can monitor the water pressure as it goes into the unit. From there water can be directed to use either city water or to fill water tank by turning one of the on/off valves, which ever one is needed. Also added a clamp on the right to hold an extra new water filter when needed. Not really needed but added a hose fitting to the panel so I have a place to keep the green/black Y hose spigot. Keeps it up out of the way until I need to use it. Now the only thing outside of the motorhome is a hose going from the MH to the city water spigot.
ID:	225178   Click image for larger version
ID:	225179   Click image for larger version
ID:	225180   Click image for larger version
Mr J is offline   Reply With Quote
Old 03-15-2020, 08:42 AM   #2
KsWhoDat's Avatar
Looks really good Mr. J! At first glance it looked confusing, but second glance shows a lot of thought went into it. I'll bookmark this so when I feel ambitious I might try and do the same. thanks for sharing.
Jim & Cyndi
2014 FR3 30DS
2005 Dodge Dakota 4WD
KsWhoDat is offline   Reply With Quote
Old 03-15-2020, 09:11 AM   #3
Excellent work!
2020 Sunseeker 2440DS Ford, Trekker cap, Topaz paint
BehindBars is offline   Reply With Quote
Old 03-15-2020, 02:10 PM   #4
Took a lot of laying out to get all to fit and work right.
Old 03-16-2020, 08:03 AM   #5
KsWhoDat's Avatar
I noticed the plug right under the water filter. Is that for washout? If so, did you install it yourself? Again, thanks for sharing.
Jim & Cyndi
2014 FR3 30DS
Old 03-16-2020, 02:35 PM   #6
NICE
RETIRED U.S. NAVY
2017 FORESTER 3051S
IN SO-CAL
Philkaty is online now   Reply With Quote
Old 03-16-2020, 10:34 PM   #7
ImQAJack's Avatar
backflush/siphon valve missing
Mr J, Looks like you did a lot of thought and planning. Looks good with one exception. You don't have an anti backflush/siphon valve installed between you shut off valve and the blackwater flush inlet. With a single input line, this a health department requirement by most states (a really good safety item). Luckily you have enough room to install one.
2017 FR3 30DX
J. Moore USAF Vet / Retired QA Inspector Boeing Com Aircraft
ImQAJack is offline   Reply With Quote
Old 03-16-2020, 10:44 PM   #8
I'm guessing you are referring to the black and green Y fitting. At this time it is not for Blk tank flush. It only has a dummy hose fitting mounted in the panel for now until I am ready to put Blk tank flush system in.. I just use it to hold my hose Y adapter to keep clean and up out of the way.
Old 03-16-2020, 11:11 PM   #9
ImQAJack, You are right, I do not have a backflush/siphon valve installed, mainly because I do not have a back flush system on the unit yet. At this point the only water coming in goes either to the onboard water holding tank connection or to the fresh water fill connection. The only back flush valve is built into the water inlet that is mounted on the outside of the unit by the wheel well. I plan on adding a back flush system to the unit at a later date. Thanks
Old 03-17-2020, 11:48 AM   #10
ImQAJack's Avatar
Mis-View (alt Config)
Mr J, Yes your right, I was in error. I've been warning lots of other owners of different units about hooking up the backflush system to there main water without vacuum breaker/anti-siphon values. I attached a pic of my original (factory conf) and my modify system.
Another item you may consider. I remove factory light an installed a led light strip controlled a mag switch. The strip light is mounted to the interior side of the door frame.
Name:	1 - FR3_30DS_ext_plumbing_bay_WDP (2).jpg
ID:	225309   Click image for larger version
2017 FR3 30DX
Old 03-17-2020, 02:03 PM   #11
Looks good, so many ways to re-configure these units. I am doing the same thing with the shower hook-up as far as using a GH. Have the adapter for the garden hose, just didn't have it on when I took the picture. Do you have much pressure when using the GH from the shower hook-up?
Mr J
Retired QA Director - Aviation
2014 FR3 25DS
Old 03-17-2020, 05:45 PM   #12
ImQAJack's Avatar
Mr J After opening the hole dia in the facet spigot to .375", I got resemble water pressure/ flow even on the freshwater pump.
2017 FR3 30DX
Old 03-17-2020, 10:46 PM   #13
Thanks, I thought I would need to drill out that tiny hole, didn't look like much water would flow through it. Will give it a shot.
Mr J
2014 FR3 25DS
fr3, water
