10-24-2019, 06:00 PM
Anyone know where the Microwave fuse is?
2015 FR3 DS30
Microwave won't turn one when plugged in or the generator is on. Plug right next to it works great.
TV turns on and everything.
2015 FR3 DS30
Franklin, TN
franklinrvrental.com
10-24-2019, 06:18 PM
Perhaps the circuit breaker on the panel is tripped. Does the outlet have power?
Cedar Creek Lake, Texas
2019 Keystone Loredo 290SRL
Andersen hitch
10-24-2019, 06:56 PM
Yes, outlet has power. Tried the circuit breaker first.
2015 FR3 DS30
Franklin, TN
10-24-2019, 07:06 PM
microwave is 120 volt ac. it will have a circuit breaker, not a fuse.
2015 cardinal model 3825fl
2015 dodge ram 3500 dually
10-24-2019, 07:25 PM
Checked the main circut breaker but didn't see a label for "Microwave". Still flipped them all and nothing changed. But that's good to know it's not a fuse.
2015 FR3 DS30
Franklin, TN
10-24-2019, 07:30 PM
I expect the microwave is on its own circuit breaker.
... although some microwaves have a small internal fuse.
10-24-2019, 07:34 PM
some others have reported problems with the microwave. seems some units have a switch that allows a fireplace and microwave to share (either/or, not both) a common circuit breaker. don't know if this applies to you or not.
10-24-2019, 07:39 PM
Microwave
Hello, were you using it when it stopped working? I had that happen to me once, and it took awhile for it to reset. I'm guessing mine had got too hot, and a thermal fuse inside the unit tripped.
10-24-2019, 08:26 PM
If the outlet has power, as you indicated in post #3, then the problem is internal to the microwave. As indicated above they often do have an internal fuse. You will have to open the microwave to find it.
Andersen hitch
10-24-2019, 10:09 PM
Try resetting the ground fault receptacle in the bathroom.
2015 fr3 30DS, added 2nd A/C-Heat Pump, both A/C have EasyStart, Auto Transfer Switch, CHF with Hellwig Links, Progressive Power Management, TPMS, Blue Ox True-Center, Koni Shocks, HID Headlamps, LED Foglamps, Pioneer Stereo, Keyless entry, Auxiliary Cooling Fans for A/C Condenser, dashcam front-rear, Yokohama Tires, air ride seats, onboard air compressor, 3000 watt hybrid Victron inverter Venus Generator Control, centramatic wheel balancers
10-25-2019, 03:17 PM
Pockets
Sometimes, you could trip the GFI breaker if you use too many appliances on the AC outlets. If that happens, none of your AC outlets will work til you reset the breaker. Or what Hogg said
Bob & Kelley
2015 Flagstaff 26RBSS
2014 FORD F-150 Supercrew XTR 4x4
3.5L Ecoboost, 3:73 axle, Max Tow Pkg 2015(36 nights) 2016(74 nights) 2017(174 nights) 2018(157 nights) 2019(79 nights) 2020(108 nights)
10-25-2019, 03:23 PM
The OP said in post # 3 that the outlet has power. Suggestions to get power to the outlet are most likely not useful.
10-25-2019, 03:25 PM
See this:
10-25-2019, 03:42 PM
2016 Shamrock 183 Hybrid
Treat Like any other 120Volt appliance.
Most often the microwave is plugged into a dedicated outlet.....find it.
Then plug a 120 volt light into the outlet to check it. Then plug the microwave into an extension cord from a known good outlet.
10-25-2019, 03:48 PM
He states the outlet has power and is working!
10-25-2019, 03:49 PM
How much power does a microwave need? See this:
10-25-2019, 03:57 PM
If, as it sounds like it does, the plug has power that the microwave is plugged into, then look for a internal fuse that is located IN the back of the microwave.
Look for a diagram for the model of the microwave and that should show you where the fuse is. You will have to put in the very same fuse as that is in the microwave. Do you know how to test the fuse in the microwave to see if it is bad?
Unplug the microwave when working on it.....
Brother Les
10-25-2019, 04:01 PM
I think that all microwaves have an internal fuse of some type.
Brother Les
10-25-2019, 04:06 PM
I do, too... but over the last 2-3 years, I've become less definitive because someone generally says "well, what you just said ain't true about mine."
