Originally Posted by DavidShifflett
I have a 2016 FR3 28ds with an awning that will not extend or retract. I checked and still replaced the fuse - still wont work. I tried looking for a wiring diagram for the switch due to it having five wires not four. I can due basic wiring but when they through in extra wiring it gets out of my depth. But if I have a wiring diagram with the ohms and or amps I can work it out.
Does any one have or know where I can find this diagram? Thanks in Advance!
David, First things to do is get your ladder and voltmeter, take the connection apart at the motor, check for voltage while your helper is holding the switch, trying to run the awning out or in. If nothing, check at the switch for voltage. Just keep on tracking the voltage. Could be a pinched wire in the awning framework, could be inbetween. One other spot to check, do you have a remote control device for this awning? Perhaps it was turned off on it. Those things toss some weird conditions sometimes.
Does all the rest of the 12 VDC system work?
