Old 08-12-2022, 10:38 AM   #1
Battery Panel..Fr3
Can someone please tell me when the battery should be dissconnected or connected please....ty
Unclesam is offline   Reply With Quote
Old 08-12-2022, 12:24 PM   #2
FR3 Representative
Typically you would turn the battery disconnect off when you are putting it in storage or if you are going to be away from the motorhome when you are not hooked up to shore power or running the generator.
You want to make sure that the battery disconnect is turned on when you are using the motorhome. It will allow the power converter to charge the battery when you are hooked up to shore power, running the generator or driving down the road.
Steve Sobkowiak
FR3 Factory Representative
ssobkowiak is offline   Reply With Quote
battery, fr3, panel
