04-26-2017, 08:54 PM
#21
Plastic does not seem as strong, some seem to give a bit. Had an office trailer at construction site, two women that worked me for threatened to quit over cheap plastic seats. Too cold to the tush! Had plumber change out to wood. Happy ladies. Outside temp was in low 20s and bathrooms did seem to be much warmer.
2020 Georgetown 31L, Safe T steering, Sumo springs, Onan Geny
2015 GMC Canyon 4X4 TOAD w/Blue Ox tow plates, InvisiBrake
Pepper 🌶 PomChi rescue 545 nights as our camping buddy
Days camped in FR 2011-12 = 77, 13-14 = 98, 15-16 = 129
17 = 81, 18 = 44, 19 = 83, 20= 45, 21 = 76, 22 = 57, 23 = 42
Retired :
04-29-2017, 02:51 PM
#22
Has anyone replaced with a Dometic 320 elongated ceramic toilet
Has anyone replaced with a Dometic 320 elongated ceramic toilet?
Our 28DS Bathroom is the same as the 30DS.
We have an elongated in our home.
310 CERAMIC TOILET
Dimensions product depth 19 "
Dimensions product height 20 "
Dimensions product width 15 "
Net weight 26 lbs
320 ELONGATED CERAMIC TOILET
Dimensions product depth 22 "
Dimensions product height 19 3/4 "
Dimensions product width 14 3/4 "
Net weight 37 lbs
04-29-2017, 02:58 PM
#23
I use ordered one from Amazon, it should fit, looks like you have plenty of room, more then our 2017 29ds
05-21-2017, 01:01 PM
#24
We went with the 310 with a spray. Love it!!! Next up - shower head!
06-01-2017, 12:37 AM
#25
Attachment 136268
310 CERAMIC TOILET
Net weight 26 lbs
Net weight 37 lbs
We installed the 320. It is tight-up against the wall. It does not take up anymore room.
We love it.
06-11-2017, 03:19 AM
#26
Can you tell me why you didn't like the plastic one
06-13-2017, 01:15 AM
#27
The 320 toilet is almost like the home toilet.
1> Model 300 has a cold plastic seat. Toilet seat on Models 300 & 310: Polypropylene.
Toilet seat on Models 320: Enameled Wood 2> Model 300 has a single 3-jet water sprayer in the back. The 320 & 310 toilets have many jets around the rim. 3> Main reason, if we are going to spend weeks in the FR3, we want to feel at home.
The 320 toilet is almost like the home toilet. My wife used both toilets and is glad we upgraded to the 320 toilet. (I like it also. )
We spent two night more nights in the FR3 this weekend. I learned how to use the black-tank flush with a 5" clear sewer hose adapter. This was my first motor-home with a black-tank flush.
01-02-2018, 03:34 PM
#28
We are getting ready to replace 300 with 320. It sure as heck smells like the seals have gone bad on the 300 anyway. Question, do these toilets need a wax ring like a residential toilet?
01-02-2018, 03:49 PM
#29
No wax ring.
It uses a rubber gasket.
Easy swap, I did ours.
Henry & Cindy
2021 Coachmen Encore 325SS
2019 Edge ST
01-02-2018, 03:56 PM
#30
Originally Posted by Herowe
No wax ring.
Did the toilet come with the gasket or did you have to purchase it separately?
01-02-2018, 04:00 PM
#31
It came with the rubber gasket.
Great upgrade.
No more noisey seat and it feels like home.
Henry & Cindy
2019 Edge ST
01-02-2018, 04:06 PM
#32
Great upgrade.
Awesome! Ordering it now. Thank you.
01-02-2018, 04:16 PM
#33
I upgraded to the Domestic 320 two months ago on our 2016 30DS. What a improvement that I would highly recommended and easy to install.
01-03-2018, 09:25 AM
#34
We love it.
We used the new 320 toilet until we winterized our FR3. We still love it.
Next improvement is more Batteries and a Power Inverter.
01-03-2018, 10:13 AM
#35
Originally Posted by Oaklevel
What does your bracket look like they use several types. Our bracket is similar to this and looks to be 30-40 lb capacity.
ramco-eng.com
Little bit of overkill for a toilet paper holder, but I like how you can position the roll right where you want it.
I put pieces of split fuel line on the ribs under the seat after our first trip. It does make it quieter but I loose one occasionally.
2017 Rockwood 2703WS - Sold
2015 Keystone Sprinter 333FWFLS
2017 F250, 6.2 Gas, 3.73 Axle, 2902 lb Payload
If women don't find you handsome, at least they should find you handy!
01-03-2018, 02:18 PM
#36
To answer the question of why- it is cleaner- does not hold onto odors- can use a regular toilet seat for comfort- does not rock- looks better.
I have done several and found the easiest way to take out old toilet is with my Sawzall. I simply cut it in half, the bolts are then easy to reach.
Chummy V
2014 Forester 2501TS
Ford E-450
01-11-2018, 11:45 PM
#37
Converting to porcelain toilet
New toliet is in. I have never been more excited about a toilet. Our bathroom reeked like piss no matter how much we cleaned and when removing the plastic toilet, I found it had piss in the back where there is an opening and a cavity. My disabled son’s aim is not the best, mystery solved, no more opening and cavity either. Win-win.
