Old 12-03-2014, 07:54 PM   #1
Defroster only
I am only getting air out of the defroster vents. Before I make the two hour trek back to the dealer does anyone have any ideas what the problem may be?
PhilZ is offline   Reply With Quote
Old 12-03-2014, 08:00 PM   #2
When you turn the knob for the regular vents, do you hear any noises under the dash? It could be the damper (air flow diverter). Mine failed a couple of weeks ago on the Dodge. $170 to fix.
Richard6959 is offline   Reply With Quote
Old 12-03-2014, 08:14 PM   #3
Unhappy
No noises from under the dash and if I manually push the damper/diverter close air will then come out the vents, but I also do not think there is any vacuum to/from the damper
Old 12-03-2014, 09:48 PM   #4
Is this an e450? If so I would call your local ford dealer if it is still in warranty. That is probably where the rv dealer will take it.
2015 Sunseeker 3170ds
TakeItEasy is offline   Reply With Quote
Old 12-03-2014, 10:23 PM   #5
Bobb36's Avatar
I would take a look at the vacuum lines, sounds like one fell off going to the heater controls
2014 FR3 30DS
2014 JEEP WRANGLER WILLYS
Bobb36 is offline   Reply With Quote
Old 12-05-2014, 07:03 PM   #6
Problem solved!
After several hours of tracing all six vacuum lines found the one coming off the vacuum tank kinked as it passed thru the firewall. Problem solved!
Old 12-05-2014, 07:31 PM   #7
acadianbob's Avatar
Nice problem solving!!
2021 F350 Lariat 7.3 4X4 w 4.30s, 2018 Wildcat 29RLX
Red Green coffee mugs
acadianbob is online now   Reply With Quote
