Was trying to find my old thread didn’t see it sorry for the new thread….so here it goes….
Tested out the dish setup at home on a normal tv all good ready to roll. Tried to follow diagram Brent posted while still home no good. Was day before leaving so was supposed to be packing up….yeah we have all done it [emoji3]
Woke up in the am had breakfast and said this is it I am gonna make this work
I was thinking and thought the outside tv coax Might work and tie that from the splitter pic attached. The pic the tan cable is antenna from park.
So took cable from splitter tried each of set one and two. Neither worked to get the signal to the antenna never saw switch from the Wally
Out comes the techie in me. I ran direct thru window with all cables and couplers I was using and everything worked. So it is only when I use the internal wiring that I get no luck
I did a last ditch effort plugged into park cable port with dish and took brown/tan cable direct to Wally with no luck
I ensured no power on booster and no power on antenna.
Also as a side note even when running park cable it’s super snowy and not clear.
Any thoughts?
